Page 1 of 3 123 LastLast
Results 1 to 10 of 27
Thread: SJS Arcadia Model 7 Line Pre-amplifier
    I'm Simon.
    Default SJS Arcadia Model 7 Line Pre-amplifier
    Following on from the successful launch of the Model 3 MM RIAA phono amplifier, and the Model 5 Stereo SE 300B Power Amplifier, SJS Electroacoustics are pleased to present the new Model 7 line stage pre-amplifier.
    The Model 7 has been designed as the 20th Anniversary re-imagination of the original Arcadia Model 1 line stage preamplifier, which was first delivered to customers in early 1997.
    The Arcadia Model 7 line stage is based upon the same 6111wa NOS military valve and has been specifically engineered for sonic performance rather than technical specification, and fulfils all SJS Electroacoustics primary design criteria:
    • Single Ended circuit topology
    • Pure Class A operation
    • Zero negative feedback
    • Valve rectification and choke-input HT power supply
    • Custom made HT T-network power supply capacitors with silver leads
    • Point-to-point circuit wiring without PCBs
    • Hand built
    • PTFE board for component mounting
    • High quality components throughout
    • Custom made aluminium chassis
    Bespoke customisation of the internal components is possible to meet our clients' specific requirements, whether it is replacement of the Audyn capacitors with Dueland RS or CAST or possibly even using Tantalum film resistors, for example, these can be discussed at the point of ordering.
    Each amplifier comes with 2 years parts a labour warranty, except for the valves which have a 6 month warranty.
    Further details can be found on the SJS Blog
    SJS Arcadia amplifiers are available from Definitive Audio in Nottingham
    SJS Arcadia Line Level Pre-amplifiers, Headphone amps, MM Phono Stages and SET Power amps - service, repairs, upgrades.
    Designed and hand-built in England.
    Looks very nice Simon!
    StSt Motus DQ + SME 312 'MB Special'
    Transfix Axia / HM7
    Art Audio Vinyl 1 Ref
    Modified Mac Mini/Weiss DAC 202
    SJS Model 2
    BP P20 (SJS upgraded)
    Trenner and Friedl RA
    [/SIZE]
    I'm Julian.
    Maybe I'm missing something but couldn't find any details about SJS on the Definitive Audio website ...
    Sonore Rendu - Cambridge Audio Edge W - Sonus Faber Venere 2.5
    I'm Simon.
    Quote Originally Posted by julesd68 View Post
    There is a small piece in the news section as they have just taken the amps on (again)...... more to follow
    Definitive were one of my dealers back in the late 90s so it's good to be working with them again.
    At the moment, the most info is on my blog:
    Sjselectroacoustics.blogspot.co.uk
    Or ping me a message if you want to know anything specific.
    I'm Simon.
    That looks exquisite. No wonder Definitive have picked you up, Kevin knows quality.
    I'm Phil.
    prices would be good too
    Eric Bibb
    I'm Simon.
    Quote Originally Posted by hifinutt View Post
    We are running a 20th Anniversary 20% discount for all amplifier orders placed before the end of 2017.
    I'm Phil.
    sounds good , 20 % off what though ?
    would this performance fall below the 1.5 if it is based on the 1 ?
    Eric Bibb
    I'm Simon.
    Would this performance fall below the 1.5 if it is based on the 1 ?
    20% off the inc vat list price of any of the new amps: Model 3 riaa, Model 5 se 300B, Model 6 riaa, Model 7 line, Model 8 se 300B amp, Aoide headphone amp
    The Model 1 was the original steel case entry level unit form the late 90s, the Model 2 was available at the same time as a higher spec copper case version of the same design. The Model 1.5 is a name coined to refer to the original Model 1 units which have been back for a significant upgrade to the internal parts to move them towards the performance of the Model 2. A number of these Model 1.5 units have come about over the past few years.
    The Model 1, Model 1.5, Model 2 and Model 7 are all the same basic circuit design, using the 6111wa valve. The difference is in the execution, parts, layout and chassis material.
    I have a fully modded Model 1.5 here for comparison, and the Model 7 in the photos comfortably outperforms it.
    I'm Phil.
    brilliant , thanks for that
    Eric Bibb
