Results 1 to 3 of 3
Thread: Project surprise
    I'm Ian.
    Default Project surprise
    A friend asked me to look out for a budget turntable for him as his current one beside being nasty was expiring. Budget was set to £200 but less spent the better, had to be black and in great condition. After a fair bit of hunting the usual places I came across a Pro-ject Debut 3, as new condition with all original bits and pieces and packing for £130. The cartridge was AWOL but thanks to Jerry an AT95e was sourced for £15.
    It's all set up, dead easy as not much to set up, and I can only describe the result as astonishing, if a budget turntable costing only £145 all in can sound this good then things have really moved on. Obviously it has it's limitations but it retrieves so much information from the records it would definitely embarrass decks costing hundreds of pounds.
    To sum up anyone looking for a budget turntable it's well worth hunting one of theses out.
    [IMG][/IMG]
    Turntable
    CD
    Network Player
    Cambridge NP30
    Amplifier
    Speakers
    Cables
    Headphones
    I'm jamie.
    that reminds me of the revolver tt i had.
    My System
    John Wood KT88 Amp.
    Paradise Phono Stage
    Sony TTS-8000 Turntable.
    PMAT-1010 MK6 Tonearm.
    Ortofon Cadenza Bronze
    Sony X555ES Cd Player
    Yamaha NS1000m Speakers
    I'm Anto.
    They are nice TT's . I have the Project Debut Carbon , with the Orofon Red and it does not fail to impress !! Its in Blue , maybe a mistake , but it was reduced when I bought it new 12 months ago !
    Not really sexy enough for me though !!
    But I cant wean myself off detachable headshells and s shaped arms , so my day to day TT is a Ferguson
