Page 9 of 10 FirstFirst ... 78910 LastLast
Results 81 to 90 of 91
Thread: Cagey's first Audio"fool" Mains Cable
  1. #81
    Irrespective, captive mains leads are a right PITA!
    If you use 8 powered components to play a record they are. That must have got out of hand a while back.
  2. #82
    I'm Kevin.
    But it is true that roof coverings don't make a difference, as long as they are fit for purpose.
    I don't think I mentioned RF screening? If that was the only difference, then maybe I should try screening a standard cable. I also did not imply that they filtered out noise. I would love to know how they create the difference I perceive, but I am blissfully ignorant and have let my ears lead me astray.
    I never thought that cables could make a difference, until I tried a few different ones.
    Kevin
  3. #83
    I'm Deleted.
    Default Cagey's first Audio"fool" Mains Cable
    Nah, it's fine........
    (There's only seven powered components - one needs two mains leads)
    Account Deleted
  4. #84
    I'm Jez.
    It's a bit of an academic issue if one has to be 'begged' to build such equipment. It may as well feature its own internal generator as none will ever be built.
    A very silly reply Mark. People would indeed have to "beg" me to make Paradise clones, which is of course what you are referring to, as I have designs of my own. I did write a bit of a rant about the industry at this point and why I haven't really done much about it but I won't bother....deleted.
    Making the cut-out for an IEC mains socket with combined fuse and on-off switch takes over an hour in labour when doing things by hand as I do... It's a right PITA!
  5. #85
    RothwellAudio Guest
    Quote Originally Posted by Arkless Electronics View Post
    Here's a punch for IEC sockets without fuse and switch http://uk.rs-online.com/web/p/punch-...tions/0543614/
    They've gone up in price since I bought mine!
  6. #86
    RothwellAudio Guest
    No, you didn't mention RF screening, and neither did I. I mentioned RF filtering, which is something else. Shielding a mains cable wouldn't filter out any RF that it was carrying, only prevent it from picking up more.
  7. #87
    RothwellAudio Guest
    I forgot to mention that it has "internal filtering inside the plug and IEC".
    This would be where I got the idea of RF filtering from.
  8. #88
    True - to help remove any cable-borne RF, the use of extenal ferrite camps might be beneficial. They're inexpensive and can be removed if ineffective. Just some experimentation is needed as to where on the mains cable they are fitted. Usually nearest the mains plug is best, but not always.
    I'm Kevin.
    A good point, well presented.
    I expect that the "filters" are just ferrite rings.
    Kevin
  10. #90
    I'm Dennis.
    This thread has just reminded me that the BBC used to use thick mic. cable for feeding mains into amplifiers, I remember baulking at it, but great care was taken with insulation of the screen from the rest.
