Page 4 of 10 FirstFirst ... 23456 ... LastLast
Results 31 to 40 of 91
Thread: Cagey's first Audio"fool" Mains Cable
  1. #31
    Okies... What we really need to establish is what the "bespoke cable filters" in the plug have been designed to do (filter out), and whether applying such filtration *at source* (before your regenerator) could be making its job easier, thus allowing it to function more efficiently, which may be one of the reasons why you're hearing improvements using this cable.
    Aside from the high-quality construction of the cable in question and its connectors, the electrical and sonic effect of which I'm familiar with in my own system (as I use a non-filtered version of the same cable), the fact is that ALL filters, when introduced into the mains supply, do something, bad or good.
    They simply don't do NOTHING, and I'd wager that the plug filters in question are somehow influencing the performance of your regenerator unit and improving its efficiency, or impacting positively on the mains in some other way. It'd be interesting to measure the waveform on your mains supply, before and after simply changing the cable on your regenerator (and also note readings, in terms of any reduction in impedance) and see what happens.
    Anyway, we can surmise what may be technically responsible for any change occurring with the use of this cable David sent you, until the cows come home, but the most important thing is that YOU can hear improvements that have resulted in YOU enjoying your music more. Subjectivists use their ears to build their systems, not test equipment, so they will always act as the final arbiter.
    Enjoy
  2. #32
    I'm Kevin.
    One of the things that may lead to a better, more open sound with the cable is the increase in conductor cross section, the drain wire and the screening. I believe that my standard cable is a 1mm CSA conductor. Not particularly big for a cable feedback by the entire system. It may have been creating a bottleneck when peak current demands were occurring.
    Either way, I hear a difference with this cable (otherwise I would have sent it back) and that is all that matters.
    Others can believe what they want, but until you try it, you will never know if you would hear a difference or not.
    Kevin
  3. #33
    I'm Brian.
    Exactly
    Regards
    Brian
    Amplifier : Sony TA FB740R
    Speakers : Tannoy 637
  4. #34
    Indeed, and furthermore, the notion that absolutely *everything* in audio, which with the scantest of thought applied, seemingly doesn't comply with the laws, as outlined in 'Johnny's book of physics', or appeases one's blinkered and entrenched 'world view', must automatically be imagined, is more laughable than anything Kevin's done!
  5. #35
    Kevin, I've been taken to task for not replying to you here, so here I am..
    Why didn't you, or why don't you, try a Mark Grant mains cable for fifty notes or thereabouts. Mark's already stated the current rating in the past (I forget the exact value now, but it was here on AOS), and it was higher than the £400 Naim one which started that particular conversation. I find this cable works well in the main system either because of, or in spite of, the increased conductor area and shielding. The plugs are proper UK standard too, and it's not expensive when labour in making it so neatly is involved. Worked for me over a shorter home made cable with similar IEC and MK 13A plug.
    I do hope the magic ingredients in your new cable aren't of the VDR variety. We 'did all this' back in the 80's and after acknowledging a difference, the general eventual conclusion is that they were worse on the whole. Glenn Croft used them for a while and in recent years, he recommended I remove it from the old preamp I had, as well as the pukka mains filters he used to made (I still have them and continue to use the 4A one on one of my sources, I think it's the turntable). Although 'filters' are deeply frowned on in these circles, the Roxburgh 6A filter from Farnell (also fifty quid) works a treat on older noisy digital sources and I understand these filters work both ways, preventing less well designed power supplies from polluting other gear in the system..
  6. #36
    Easier said than done. What aspects of the Waveform are you trying to measure? Even if you did measure a difference how are you going to attribute a specific difference in sonic presentation to any one of the specific changes in the waveform? More importantly how are you going to prove which part of the mains lead created the waveform difference in the first place?
    PRE
  7. #37
    I'm Kevin.
    I am still waiting for Mark Grant to get back to me after contacting him by e-mail (several times), hence going elsewhere.
    I know he is a busy chap, but it is not always convenient for me to contact a supplier by phone. My job sometimes requires my phone to be turned off.
    Kevin
  8. #38
    I'm Kevin.
    I am quite happy with this cable, so I am thinking of ordering another three very soon.
    Maybe I will,get a bulk discount if I ask nicely?
    Kevin
  9. #39
    All good questions, Andy! Sadly, I have no suitable answers.
    All I was doing was putting forward possible suggestions as to what might help explain the improvements Kevin is hearing. How those would be carried out, however, is up to anyone who wishes to try them.
    Trying to dig deeper into explaining the possible cause, is certainly better than [like some] immediately dismissing out of hand Kevin's legitimate experiences, simply because what's been reported doesn't fit with their rather blinkered world view!
  10. #40
    For me, not being able to answer this question is the biggest problem with this addicton (sorry I mean hobby). I'm not so sure about changes with power cables. I find changes hard to detect but this is maybe because I've made all my own? Now with respect to tonearm cables and IC's I don't seem to have the problem and can detect subtle and sometimes profund changes. I understand that a lot of effects and variables can be measured but we can't attribute these to certain things we hear. I don't have the equipment, time or patience (even though I could) to explore this section of my hobby. So, I have decided to have lots of fun assessing, buying, and making kit to produce a system which suits my tastes. I use my ears as guides and if I like something it stays in the system(s) or gets swapped or sold on.
    PRE
