Page 1 of 3 123 LastLast
Results 1 to 10 of 25
Thread: Sonic Signature
    I'm Rob.
    Default Sonic Signature
    I have often seen people say that when they get a new component or up-grade an existing one "it does not seem to add or subtract anything" which suggests that what they are hearing is to them a purer representation than what they were hearing before.
    How do you know?
    Quote Originally Posted by Puffin View Post
    How do you know?
    Always cracks me up, that one. Unless you were present at the recording session, the only insight you have into the recording is listening to it via one or more different systems. There's no way of knowing what a particular component has added, taken away, or changed.
    Box swappers can tell.
    Martin
    Technics SL1200P CD Player * NVA P90SA passive pre / Krell KSA50S Power amp * JM Lab Electra 926 loudspeakers *
    'The best I advice I ever received was to always remember that no-one else has any idea what they are doing either.'
    I'm GettingFunky.
    X swappers can tell it sounds different from the last system they heard it on.
    Contemplating life, the universe and use of HiFi forums.
    Life is too short to worry about the opinion of others.
    If you hear more detail, more transparency, tighter bass and so on. Has something been added? Or has something been taken away?
    Different, maybe. Closer to the original? How can they tell, apart from a vague feeing that 'it sounds so good, this must be how it was meant to sound'?
    You really want a serious answer to this question? Okay,
    1) we are attempting accurate replay of the original recording post mastering, not re-creating the original performance. No need to have been there for any of it.
    2) If it sounds good you are on the right track as almost all recordings sound good if the kit isn't cocking them up.
    3) All recordings have to sound good not just girl with guitar or bloke playing cello - no exceptions. If so you are on the right track. If not and only some recordings sound good that is because the kit is faking it by adding 'sonic signature'. All kit has sonic signature, especially speakers, we can't get away from that but the less signature the more likely all recordings will sound good.
    4) 'Sounds good' does not mean you decided you liked it. If you have to analyse then it isn't that good. You know good when you hear it. No thinking needed.
    Martin
    I'm Rob.
    It is all subjective though isn't it?
    It's only subjective around the edges.
    Martin
    Even objectivism is open to interpretation, making it all subjective.
