Hello people.
Just need some advice if someone can help what you think that is best way to do it.
I have ordered some 24 AWG Precision Shielded Silver Plated Clear PTFE Twisted Pair Wire from USA to do some DC umbilical cable for linear PSU.
http://www.ebay.com/itm/10-feet-24-A...3D231928380607
And I have 1 meter left so I have decided to try to make RCA interconnects since I have some spare RCA plugs.
Since wire is 2 conduct with shield and for pair I will end up with 2 X 50 cm of wire I would like not to solder end resolder again.
What would be yours advice how to do it. Searching on web I have found 3 solutions. One is to complicated for me so I will stick to next two.
Should I twist both wires together and use like one wire and use shield like with coax cable.
Or should I do it....on one end(to source component) of interconnect neutral + shield connected together on the barrel...and on the other end(target component) shield completely isolated...just neutral line on the barrel.
I am now using cheap qed performance audio 40 for that job and I am satisfied but just want to see is there gonna be any difference in sound and what kind.
Many thanks!
Nikola
