Blending a sub can be tedious work, as pointed out different recordings call for different settings. A happy medium is all we can hope for, best of luck!
Had a quick play this morning while the kids were stampeding around, the settings from last night were a bit bassy at higher volume (I guess it's like a loudness control quite handy in fact) but toned down it sounded very good indeed. Yes I agree it should sound natural and subtle. I have placed it to minimise phase effects, the only thing is as you adjust crossover you have to also adjust volume to maintain a balanced not overblown (or conversely too subtle) sound.
Also, I would guess its harder to blend infinite baffle speakers with a sub as the roll off at the bottom end is much slower and they might crossover too much of the frequency range, fortunately mine have small front(slot) ports.
What is the frequency response of the sub you have got?
Its15-240hz (no db rating but I'd imagine -6db at 15hz, I wouldn't want much more), 8" woofer with a 50w Rms amp in a. dinky little cherry box about 12" cubed. Just right for my small AP towers to give them a bit more range. No point in anything bigger for my needs.
http://www.superfi.co.uk/p-5897-disc...subwoofer.aspx
When they don't quote any level then it usually means what is euphemistically called 'useful output' i.e 24dB down at the bottom rating.
But you don't need to go anywhere near that low unless you are very serious about pipe organ recordings. :
I use the same with a Yamaha sound bar on the telly. Decent bit of kit.
Hunter S Thompson
Most folk wouldn't notice if there was no bass below about 50Hz. In fact most don't own equipment that can do 50Hz.
I do enjoy a bit of solid deep bass myself, which is why I used to build transmission line speakers.
