Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
Thread: SPDIF output to AES/EBU input
    I'm Gareth.
    By the way Gareth, whereabouts in Chelmsford are you? I live in Great Baddow.
    Opposite corner to you, Newlands Spring area. Or Broomfield if I want to sound posh; Melbourne if I don't
    I'm Ian.
    I don't think that you can do what you are trying to do as the signal is different for S/PDIF for coax and AES. It isn't as simple as matching impedance like it is with analogue signals.
    https://en.m.wikipedia.org/wiki/S/PDIF
    I'm Gareth.
    I believe you're right. Info I was able find online suggested it might be possible, but not in my case.
    This article sheds some more light onto the subject . http://www.rane.com/note149.html
    I'm Phil.
    I might be a bit thick here but I use a digital cable acoustic zen with rca to aes from the co-axial output to the aes input on my dac . sounds just fine
    Eric Bibb
    About half way through the article there is a heading 'Conversion Caution' that seems to deal with the issue. Of course they may be wrong. I am interested because it would solve a lack of inputs problem with my DAC.
