Results 1 to 10 of 18
Thread: Using bi wired speaker cable with speakers set up for single i.e. Two binding posts n
    I'm steven.
    Default Using bi wired speaker cable with speakers set up for single i.e. Two binding posts n
    At the moment I use atlas mavros bi wire I was using it with my Wilson benesch actors so no problem they are bi wire enabled four binding posts I have new speakers now these are single wire enabled two binding posts.I spoke to the engineer at atlas and he said the solid wire was the high frequency and the multi stranded wire was the low frequency at the moment I have the high frequency cable in the positive binding post and the low frequency in the negative binding post and the other two plugs taped off I wonder if I'm wired up correctly
    If you can't connect both red to the red binding post and both black to the black binding post then I would use the 'low frequency' multi stranded pair, not mix the two.
    +1
    'ANDSOME IN THE SUMMER..'ORIBBLE IN THE WINTER. Barney Milne
    Cambridge Audio CXN, Seagate nas drive, Michell Gyrodec SE, SME309, Benz M2 Ruby cantilever, Denon DL103, Primare R32, Densen D20, Densen D30, Cambridge Audio 840A V2 integrated, Pioneer SX-N30AE Network Stereo Receiver, Roksan Darius speakers, Technics speakers, Canon speakers, Bastanis Dragonfly Horns, REL Storm III sub, Target R1 speaker stands, Atacama Equinox.
    I'm steven.
    I can wire both red to the red and black to black the binding post has a hole so I can attach there and the knurled knob has a hole on its surface so I can attach another plug there apparently you can take these speakers back to the factory and get them to add another 2 terminals for bi wiring cheers for the help boys always appreciated
    I'm peter.
    Hi Steve it might help if you could take a photo or two and post your predicament. I sort of understand having been to yours last night and seeing them in the flesh but I am no speaker boffin haa haa don't worry there's plenty of people on the aos who will help
    BTW CRACKING SPEAKERS good choice
    HEGEL H100 integrated amp
    REGA rp6/exact cart
    REGA Apollo r CD
    NEAT ELITE SE loudspeakers
    BERESFORD bushmaster mk2 dac
    Powered by a DEBEN tracer battery
    Mc5000 klotz ms audio cables(cheers Brian).
    REGA couple 2 ics
    JEZ ARKLESS phono stage
    RUSS ANDREWS powermax mains cables
    ISOTEK POLARIS mains block
    ATLAS Speaker cables
    CREEK OBH21 SE head amp
    BRIANS silver hybrid ics
    Best way would be to get both the single and multistrand into the one binding post, if possible
    I'm steven.
    Pete I can wire both red terminations to the one binding post so no sweat sorted now
    I'm peter.
    Yep Martin that's pretty much the direction I would take
    REGA rp6/exact cart
    REGA Apollo r CD
    REGA couple 2 ics
    I'm peter.
    Quote Originally Posted by vinyljunky View Post
    Good good excellent news
    REGA rp6/exact cart
    REGA Apollo r CD
    REGA couple 2 ics
    I'm steven.
    Yep done that macca so sorted it has the type of binding post which facilitates this thanks for the input
