Results 21 to 30 of 42
Thread: Who digitizes their vinyl....
  1. #21
    I'm I'mteachingmarcotheartofpishanto.
    Because the mastering's often better than the CD counterpart.
    If you've recorded from the LP it then makes sense to stick it on yer server if you do streaming, and to burn CDs if you don't. Saves on wear and tear on the vinyl rig/software.
    OK
    I will stick with my much loved and regularly fondled vinyl
    Music , fills the gaps between silence !
    TAT Sale post Leader " Marcos Mentor "
    Also a pishanto specialist confirmed by Head Daftee
    Real name " Allen " or "Zoomer Nut”, “Numpty Napper”.
    ±± KEEP IT REEL
  2. #22
    I'm AMusicFanNotAnAudiophile.
    Try playing it in yer truck while yer driving around
    Chris
    Once we've made sense of our world, we wanna go fuck up everybody else's because his or her truth doesn't match mine. But this is the problem. Truth is individual calculation. Which means because we all have different perspectives, there isn't one singular truth, is there?
  3. #23
    No Can do , I am a good boy and a responsible driver " and all that " I only fondle when I am at home
    ±± KEEP IT REEL
  4. #24
    I'm Nathan.
    Why on earth would you want to do that
    My portable table weighs 75 pounds.
  5. #25
    I'm Adam.
    Not me! tried it years ago...not worth it
    "lack of passion is fatal"
    LP12, Kore, Lingo2, Aro, SKale / DV XX2Mk2 / Garrard 401 / SME 3012 J7 Rewired / Ortofon Vintage SPU GE /Shure M3D / AD Audio KT120 'Cannonball' mono blocks
    WAD 300b Power modded, TJ Mesh Plate Valves / David Coe AD Audio 'Satchmo' Pre & Phono / Hashimoto HM-7 SUT / Tannoy 12" MGs in Chatsworth size cabs with RFC Custom Crossovers
    Speaker Cables: Duelund DCA16GA / Rpi3 & Digi + pro / SW1X Audio Design USB-SPdif / SW1X Audio Design DAC 1 Signature / Interconnects: Duelund DCA20GA home brew /
    SW1X Audio Phono SPDIF AERO 6 / David Coe AD Audio Silver USB / Synology NAS Drive / Roon / Tidal HiFi
  6. #26
    I'm Nathan.
    I had a 45 player in my first truck. It was a 55 Chevy. It mounted underneath the dash, and was a factory option. It worked alright but it was rough on the records.
  7. #27
    Thanks for all the info chaps.interesting divergence of opinion. Just in case i fancy a hobby later.
    Grant ....
    OPPO BDP-103D DARBEE - JBE SERIES 3/M55 SAS/EMOTIVA XPS1 - TWIN PRO MONOBLOCK AMPLIFIERS - XIANG SHENG DAC\PRE\HEADPHONE AMP - TWIN AVANTREE OASIS CLASS 1 BLUETOOTHS - AUDIO TECHNICA ATH-MSR7 & OPPO PM-3 PLANAR HEADPHONES - WIN10 JRIVER23, DEEZER HiFi - ECHO DOT - SMSL M6 MINIDAC - RPI/AUDIOPHONICS - FULL RANGE TWIN TELEFUNKEN/Q ACOUSTIC BT3/CANTON SUB - P.INSPIRED MAINS REGENERATED.
  8. #28
    I'm Nodrog.
    Apart from anything else Al, there are times when you just can't risk using records. Like now for instance here. I have been breaking up a concrete slab and no matter how careful, dust is inevitable. Most of the hi-fi and the LPs are locked away in a sealed room and it's just the Mac (bad enough but I can hoover it out) as source. There is no way I can go without my favourite music for the couple of months of building work coming up so it makes sense to have everything digitised.
    Sounds very good actually. If I had to, I could listen to it quite happily on a permanent basis. It's only when compared directly that the difference becomes obvious.
    I won't be getting rid of the LPs though.
  9. #29
    I'm Steven.
    Default Who digitizes their vinyl....
    Devialet digitises phono inputs then converts back to analogue. Works really well, not least because the system uses a database with the correct settings for just about any cartridge. The USB socket is 2-way so you can take the phono input straight to a computer. Really rather clever, if not "old school".
    Aries - Devialet 250 Pro - Harbeth SHL5+ 40th LE with a REL S/2
    Aries Mini - Audiolab M-One - Harbeth P3ESR
  10. #30
    Quote Originally Posted by nthall View Post
    Did you have the hands free option?
