Ok so I'm an idiot I admit it, but can I check if there's any DC output coming from an amp by connecting a multimeter to the outputs?
Technics SP10 mk2
Miyajima Shilabe cart
Hashimoto HM-X SUT
The Truth linestage
Cary 805c SET amps
Audio Note ANe-SPX speakers
Yup, you could put a meter across it should be very little dc normally.mv,s i would think. Often it gives hum if youve got any.. unlikely to be both channels tho.
I just received the hiraga from Jake, and I'm 100% confident it was OK when he sent it but just want to check it after it's long journey before connecting it to my ANe's.
Technics SP10 mk2
Hashimoto HM-X SUT
The Truth linestage
Cary 805c SET amps
Try a spare set of speakers if youve got any. Unlikely to have developed a speaker destroying fault in transit tho. Wouldnt run a tube amp with no load, certainly not for long ..wouldnt be likely good for the transformer or tubes unless it has protection.
I'm matt.
It's good practice to measure DC offset when you receive a new amp.
Here's a good guide: LINK
My Onix oa21 has 5mv on one channel a 10mv on the other. It was higher but I matched the transistors.
Thanks for that link.... Will whip out the multimeter....
Adey
Technics SP10 mk2
Hashimoto HM-X SUT
The Truth linestage
Cary 805c SET amps
Hi Guys
This thread has inspired me so i bought a multi meter - which setting does it need to be on to check for DC current?
Novice here sorry...
I want to check my Cambridge P40...
I Read the instructions - DC current selector? - the probs on RED to RED - Black to Black? Please advice if not and will need a guide if possible?
[B]Class A , A,B Amplification[/B\]
Marantz PM4
Turntable
CD Transport & DAC & PSU
Loudspeakers
Tannoy 615 MK2
Speaker Cable , Digital Coax , Interconnects
QED Speaker Cable , Chord Coax Digital , Nakamichi Interconnect , Belkin Interconnect
http://www.sciencebuddies.org/scienc...ltimeter.shtml
Your meter should have come with an instruction leaflet though. Or, there may be a manufacturer's one online for that model.
Technics SP10 mk2
Hashimoto HM-X SUT
The Truth linestage
Cary 805c SET amps
