Results 11 to 20 of 22
Thread: So, what do upgraded mains cables do to your system?
    I'm Simon.
    Yes I agree with the previous poster I think, from what I've heard, mains cables only come into effect in improving sq in a system if you change a whole load of them, and the system is good enough as well to get any benefits of mains cables.
    From what you said about not being sure in your question, I think that's when bias might come in.
    I agree the isoteks are good and the Aquarius demo I went to at the Bristol show this year with around £2k Larsen speakers and about 3-4K of exposure amps and a CD player, revealed very good improvements with the aquarius in outright speed of attack of the amps over an IKEA powerbar. But I guess it was a noisy supply with all the demos going on, but people who have used them at home I've spoken to have all said they are good.
    With your regenerator I think you've probably tackled electricitity and say you spent equivalent of £300-£400 on power leads, I'd doubt that performance improvements would be huge. I'd rather spend it on other things I think. I might be wrong though.
    I'm Allen.
    Am I aloud to ask how old the wiring in you house is ? or is this negative
    Negative, O/P has asked for people who have heard differences to comment only. You can always start a new thread if you want a more wide-ranging discussion.
    I'm Allen.
    OK I will shut up
    I'm Kevin.
    The wiring in my house that goes to my HiFi is 12 months old. The wiring to my house is much older.
    Kevin
    I'm Allen.
    In that case I would suggest a new 16 amp ( Thicker cabling ) supply directly from your house fuse box to your hifi room first , then experiment with better quality mains leads
    I'm Kevin.
    It is a 20 amp supply that I fitted last year.
    The rules in France are different, but thanks for the suggestion.
    Kevin
    I'm Russell.
    So you're got your new power cable feeding your regenerator? I think you may hear more of a difference if you place the cable between the regenerator and your gear? Worthy of experiment anyway.
    I made my own power cable from Furutech wire and Firstwatt plugs, to see for myself if there are any gains to be had. When I first plugged it up, I swore I did not hear any difference. But over time, maybe a few days to a week later, I was suddenly noticing some improvements in high frequencies. Or perhaps better timing? When I removed the wire for a standard wire, I noticed the difference right away, when it lost these improvements. This was placed between my power filter and preamp.
    I'm Kevin.
    The power cable I have is one manufactured my MCRU.
    It's a UP-OCC screened cable, furutech copper plugs with filters fitted in the plugs.
    I had heard that people say that mains cables made a difference, but it was something I believed would make no difference, so I decided to try it for myself. I am disappointed to say that my system sounds better with it in than the standard power cable.
    Everything seems more alive and there is a better soundstage. I even got the Mrs to listen and she liked the upgraded cable better.
    Kevin
    I'm Brian.
    You did the right thing and listened for yourself Kevin . Buying more ?
    Regards
    Brian
    Amplifier : Sony TA FB740R
    Speakers : Tannoy 637
