The lighting is showing up the right one better. They are both pretty good if I do say so myself lol
They're looking good. I have some ARs I was planning on sanding down today but I'm snowed in. Winter decided to make a comeback.
http://www.parts-express.com/goldwoo...4-ohm--280-100
There were several others, but some were quite expensive. Everything one needs to build speakers is on this site.
They'd be totally unsuitable for use in the Pioneer speakers though.
Bloody cheap though. $6.37!
Those mid units won't be great. The rear enclosure is too small. Its volume will resonate high up enough for that to intrude into the mid band output, also the back of the enclosure is close to the back of the cone, that will encourage reflections to go back out through the cone. They're 4 ohm anyway (whatever that may mean, depending on the impedance curve). And, I hate drivers with fixed grilles, unless they are there for acoustic purposes (like those on the LS3/5a tweeter).
Oh, I thought you'd found the actual midrange driver from the Pioneer. Oo no, that wouldn't do.
