Originally Posted by
blackstar
I've just bought a Jelco SA-750D from petrat of this parish, as a replacement for a RB300 on an NAS Interspace Jr. If anyone can help me out on a few minor points, I'd sho appreciate it;
1. Arm position: as the arm rest has such a long 'rest' I've had to position the arm so that it is not in the 12 to 6 o'clock position, and the counterweight is slightly to the 11 o'clock position instead. Is this an issue because I'd like a nice gap between the arm rest and the platter.
2. I've set the pivot to spindle at 214mm as per the arm specs, and set the VTF to approx 2.7g to have a little listen. Safari so goody, but I need to set the alignment and stylus position; can anyone recommend a good printable protractor?
I'm sure there are more questions but I'll start off with those two.
Cheers,
M.
