I have bought a TD160 off here and having looked and read a few threads I fancy making a plinth. What timber is preferred I presume hardwood and are there any recommended dimensions thickness etc.
Dave
Dave
They're sprung, and hollow so the choice of wood doesn't really matter. You can dampen the inside and underside of the plinth if needed.
I would go with a hardwood that you find attractive, and looks good with the rest of your gear.
You can change the dimensions of the plinth to match any arm you want, and finish it however you want.
Sent from my Z981 using Tapatalk
Excellent thanks I'll dig through some bits and see if I have anything suitable.
Dave
I'm Dimitris.
I agree, some hardwood should work nicely because of the extra weight.
I love wenge. I have tried it in a preamp chassis and it was excellent and super beautiful. Really difficult to work with though. Splinters like crazy without proper tools.
Sources: Modified SL1200 MK2, Salas folded RIAA, Phonoclone, VSPS, Shelter 501 MK2, Modified Pioneer P6D6 as transport, Shigaclone transport, Peter Daniel NOS DAC.
Amplification: Custom 211 Monoblocks, Electrocompaniet AW120, Audio Research VS110, Gainclone
Loudspeakers: Tannoy Turnberry, PBN Montana EP Signature
Cables/stands: Tempflex ribbon and Twinax cables
Other: Promitheus Signature Passive Attenuator, Custom JFET - transformer preamp.
I would use a combination of woods glued together. This helps with reducing resonances. Looks good and also makes it easier to construct since you can avoid having to use a router!
Geoff
