Page 2 of 2 FirstFirst 12
Results 11 to 20 of 20
Thread: Is the SL-1200 transformer hard-mounted to the chassis? Anyone tried dampening it?
    I'm Jacek.
    I did it I used rubber dumpers for mounting cd drives.
    Black is original, red/green are from cd. Transformer is unscrewed so it shouldn't be transported in this form.
    I'm Mick.
    Quote Originally Posted by Bacek View Post
    Has this sorted your problem Jacek ?
    Technics SL1210 MK2 fully rebuilt and repainted. Ortofon 2M Black Cart, Isonoe isolation feet , MN bearing and Funk Firm platter upgrade, Oyaide RCA Tone Arm and speaker cables, Jelco SA-750D Tonearm. Oyaide HS-TF Carbon headshell, MCRU Linear External PSU, High Fidelity Crystal glass turntable matt, Blue LED upgrade, Denon AVR-2808CI Amp, Bowers and Wilkins DM602S3 Speakers,
    Black Rhodium Jazz power cables for amp and turntable, Firebottle mk2 Phono Stage.
    Here's another approach - any interest?
    More info here (in Spanish)
    https://www.hispasonic.com/foros/tra...00-1210/494953
    Apologies if this has been posted before, I only found it today.
    I'm Jacek.
    Quote Originally Posted by Dubster68 View Post
    I had no problem with it.
    Anyway on measurement there was significant improvement on quieting 50 and 100 Hz mechanical buzz. No cash upgrade worth of every penny.
    I'm Ken.
    Another recommendation for Mounting it external in its own case, that's even better isolated, both mechanically and for EMI
    I'm Jacek.
    Yes, but my way make all switches to work while with external psu Technics power switch is removed.
    I'll try external some point in time but now it's not my priority.
    I'm Ken.
    OK, maybe a later project.
    I used the switches and transformer in an external case in my own SL-1200 projects, have a look at the thumbnails towards the bottom here:
    http://www.jkwynn.co.uk/Tech_HTML/Tech_Thumbs.html
    Quote Originally Posted by dimkasta View Post
    It's not mounted metal to metal. It has rubber dampeners inside.
    If you are into mods, have a look at this thread.
    http://theartofsound.net/forum/showt...wer-Supply-DIY
    It's full of useful info and trials
    I did the DIY external power supply, it did lower the noise floor a bit. Well worth it as a DIY project.
    I'm Mick.
    Quote Originally Posted by Qwin View Post
    Some good ideas there Ken
    I'm Ken.
    Thanks Mick,
    I've done 3 Technics decks, all had a different approach and I learnt a lot along the way.
