Page 1 of 13 12311 ... LastLast
Results 1 to 10 of 123
Thread: Spending Most Of The Budget On Amplification?
    Default Spending Most Of The Budget On Amplification?
    What do people think? Some say spend most on the source, others say the loudspeakers should get the most of it.
    But is the amplification really the key to getting a good sound? Slowly dawning on me that this might indeed be the case.
    Current system if you ignore the TT which is not my primary source, and cables, I've got 65% of the spend in the amps. Never had a better sound.
    What's your percent spent on amps and what's your opinion?
    I'm Kevin.
    My primary source would probably cost slightly more than my amplification, but not much more.
    Kevin
    I think it depends on what your looking for. Yours is maybe not the norm. I would say speakers most. Then share out rest between source, cables and amp.
    Obviously it depends on budget too, but in most folks case
    Oh, and turntables are excluded
    Agree not the norm but I've always been of the opinion it was speakers first, if using a digital source. Now reconsidering that.
    The spend allocated to each part of the system should be reasonably proportionate. You don't bung a two grand MC in a PL-12D for instance (unless you are nuts ).
    This may oversimplify, but perhaps 30% on speakers, 30% on amplification and 40% on source
    In the case of vinyl, my turntable, arm and cartridge adds up to a little more than my most expensive power amps. The CD player (bought used) was £400, and my tuner only £200; so considerably less than the amplifier. My speakers can be obtained (used) for ~ £500, but an equivalent new would cost about the same as the amplifier.
    However if I were to advise anyone, I would say spend equally on the source, amplification and speakers. I'm well aware of the argument for having a good source, but all components in the audio chain are important. If you have an inferior source, then no amount of expenditure on amplification and speakers will improve matters. Likewise you won't be able to hear how good your source is if you use cheap amps and speakers.
    My speakers although homemade and relatively cheaply still added up to a fair bit. Being homemade fullrange, like most of my sets, are not really sellable but there is a lot of cash in them, and a fair bit of me. No one wants fullrange these days, they get i guess an unfair rep. Again it does depend of musical tastes and the sound you desire, or feel you desire.
    My buffer is next in cost surprisingly, then cables. Amps and cd etc lowly down list, but work well in this way. Tt and all its paraphernalia are of course more than everything combined, a couple of times probably. Looking at it that way, its a damn stupid system vinyl... lol
    Cables are the least expensive part of my system. I prefer to make my own, and usually spend no more than £10 per interconnect.
    If you bring vinyl into it then I agree it doesn't really work. But with digital not a problem. My current source is only 2.5% of the total budget. Okay that is the next area for upgrade, so that will change, but hopefully not by much.
    I'm Peter.
    I was once told by a dealer that I should budget about 30% of the system spend on cables, because "they can make the biggest difference". Strangely, I didn't follow his advice, or, indeed, buy anything from him.
