I'm tony.
In simple terms an amplifier is made up of a pre amp and power amp section.
The pre amp if a seperate component acts as a switching box-it lets you connect a number of sources like a tape deck/record player/cd player/tv. It will have volume control. record players need a phono section that boosts the wee delicate signal that is generated by the cartridge on the record player.
Active pre amps need power and boost/caress the signal they receive from the source.
Passive pre amps dont need power they act as a switching box and volume control.
Power amps take whatever signal you feed them and amplify it.
The power supply can be upgraded for naim kit-thats what your looking at.
Intergrated amps are both sections of the amp in one box.
Hope that makes sense and demystifies amps a wee bit...
Enjoy the hi fi journey-it should let you enjoy your music more as you progress.
I'm jayne.
Great - thank you.. It does help! A lot to it! That's why I initially just got the intergrated amp (nice and simple for me!! Hehe!)
The Flatcap is I think, the only Naim PSU that will power two other black boxes. Check their website to see if it can power your CDP as well. I have had all the dems I need to be convinced that the off board PSUs do work and are a big step up from mains power.
Dave
Rega RP8/Apheta/Naim NAC552/NAP500/CDS3/B&W 802D3
The Flatcap is a power supply that can power two separate items, so it is a good purchase if you can use it on both on amp and a cd player. It tends to clean up the sound a little, but it's a subtle effect. However you can't use it with your cd5i. You could have used it with the cd3.5, but the cd5i can't be upgraded.
My Naim days are a while back, but I'm pretty sure of this. I had a Flatcap 2 with my cd5 years ago and I really liked them, but it won't work with the cd5i. Wether it would be worthwhile with your Nait 3 I couldn't say.
I'm jayne.
A Flatcap is a box which is mostly empty.
https://www.google.co.uk/search?q=Na...SAC-Q_11Fk9dM:
