I've noticed some manufacturers stating that their (normally KT88 equipped) amps can be used with KT120s but NOT with KT150s.
Having had a look at the data sheets I can't see any reason why not but I'm conscious I don't know a big lot beyond checking pin-outs, heater currents and max voltage ratings.
Would some of you learned chaps have a look and advise please?
I can understand that the existing amps may not be optimised for the KT150s but to say they can't be used but KT120s can
My cynical side suggests it's a marketing ploy to promote their new range of KT 150 equipped models but maybe there's more to it than that.
Oops, looks like only the 1st page shows up of these datasheets. Here's the links to the full documents.
http://ww.tungsol.com/specs/kt120-tu...ecs-curves.pdf
http://ww.tungsol.com/specs/kt150-tung-sol.pdf
