Hunter S Thompson
Mini Beast should be good on you speakers Clive, you run actively do you not?
Hunter S Thompson
Brilliant, glad you are finding your way with them .
I was a bit sad to see them go to be honest but I'm certainly not in the place to make any use of them and I know that you are so have a blast with them .
Source: Heavily modified DDDAC using MacBook Pro.
Amplification: Pre amp-Stereo Coffee pre amp on steroids.
Power amp- Rather large Colin Wonfor Class A power Amp
Speakers: Lampizator P17 Open Baffles
Accessories: Klotz 500 DIY Interconnects & DIY speaker cable sounding better than anything commercial.
All powered from a Mother Trucker BPS with a dedicated consumer unit with 10mm armoured radial back to the house tails after the meter.
Thanks mate, much appreciated.
Hope your health is picking up?
Hunter S Thompson
Further experimentation. Now using a rare pair of Crysler D 500 compression drivers with horns along with a pair of SB Acoustics Sartori TW29r tweeters. This is the best I've heard so far, though after talking to a friend who is building his own horn setup, I'm going to have to bite the bullet and go four way, I'll use a pair of Alpair A12P drivers 200-800hz, as the Eminences are not really happy going up that high.
Hunter S Thompson
Wondered when you'd get around to using those Ali.
