Page 1 of 3 123 LastLast
Results 1 to 10 of 34
Thread: USB CABLE What's the score?
Hybrid View
Previous Post Previous Post   Next Post Next Post
    I'm Adam.
    Default USB CABLE What's the score?
    can anyone recommend a sure fire winner for connecting a DAC to USB/SPDIF converter?
    The more I read about USB cables the more i get a head spin.. It really seems the HIFI world is split between a £10 cable and a £1000 cable
    Any thoughts would be great, as usual if the product is a sure winner and proven to deliver the goods SQ wise, then money spent isn't a great issue
    but lobbing good money at dubious cables is not just viable or desirable!
    "lack of passion is fatal"
    I'm Neil.
    Yep, a sure fire way is to ensure that your cable is properly certified. For example, look at the Amazon Basics cables, under a tenner.
    I take it your looking for a coaxial 75 ohm cable?
    I'm Adam.
    Yes Grant
    I'm AMusicFanNotAnAudiophile.
    I can thoroughly recommend this cable https://markgrant.co.uk/digital-cabl...gth-1_5_metres , and use one myself.
    It conforms to specification, and simply does what it says on the tin.
    Chris
    Common sense isn't anymore!
    Probably the best RCA terminated cable you can get, for a very reasonable outlay. It ought to be remembered that it is impossible for any RCA phono connection to have a characteristic impedance of 75 Ohm, but the crimped Canare designs go a long way to minimise the impedance mismatch.
    got a few around in my spare cable box. will have a look tomorrow if you want
    I'm Adam.
    Thanks chaps, very good of you, Grant thanks for the offer,
    I suppose the purpose of the op was to see if
    There has been a 'bake off' of USB cables and to see really
    If one has to spend £20 or £200 and what, if any, giant killers out there.
    I have a couple of cables I use, 1 a custom home brew, and another is a Supra USB
    I can't tell a lot between them TBH..
    I have got myself a nice digital set up now with upgraded PSUs and a lovely DAC
    And I want to maximise the SQ. I presume the cable such as a Supra is a weak link in the chain?
    if its usb cables then again thats different to 70 ohm coax. Gazjam and Tony, plus Brian of the Scottish Mafia did some A,B,C's with digital cables.(I was at some of them) pm Gaz and ask him. he knows his stuff re dig cables.
    I'm Adam.
    Sorry grant not coax I should read the question first before answering!!
