Results 1 to 4 of 4
Thread: A Pair of 500 Watt Subs
    I'm Duncan.
    Default A Pair of 500 Watt Subs
    Hi All,
    You are looking at a custom made pair of US Blaster Subwoofers.
    I was running these active but will include a pair of passive crossovers if you need them.
    These subwoofers are 2 x 500 watts and offer a great sound.
    The specifications for the EQ range can be seen in the photos.
    The speaker boxes are carpeted and have handles on both sides.
    The DUAL HIGH DENSITY STRONTIUM MAGNETS together with the extra long Kapton voice coil of 50mm diameter feature excellent thermo-conductive properties.
    thereby generating amazing sub bass frequencies.
    Features :
    - Aluminum injected polypro cone
    - Rubber surround
    - Vented dual magnet
    Specifications :
    Diameter 380mm (15")
    Power Max 500W
    Impedance 4 ohms
    Frequency range 25Hz - 3.15kHz
    SPL 89.3 dB
    Magnet 2 x 50 Oz
    Chassis Steel
    Voice coil Kapton 50mm
    QTS 0.38
    Resonant Freq 18.7
    VAS 405
    Collection only but could meet up/deliver upto 50 miles of CH64.
    £50 each or £80 for the pair.
    Happy Days
    Duncan
    Bargain alert here folks.
    I'm Duncan.
    Need to go.
    £50 the pair, no crossovers now.
    I'm Nat.
    Default Subs
    If you were within 50 miles of Brighton I would bite your hand off!!
