Should be able to get the toroid to shut up with my DC blocker and all the helpful hints off here. It's already 20% quieter and I haven't had the top off to play about yet.
Glad I asked, cheers all
Lovely helpful forum.
We are the love we leave behind.
A picture of the amp would be a big help. For example, where are the vent holes (if any)?
Anyway, it's possible that the movement of the metal top plate isn't in itself a problem - it could be that the top plate is "chattering" where it comes into contact with the sides. Sometimes just adjusting the tightness of screws can tune it out.
If it was mine I would look at all other alternatives before applying sticky stuff.
It's an Advance Acoustic MAA-406, I'm afraid I still can't manage to post pictures but here's a link to google images https://www.google.co.uk/search?q=Ad...w=1366&bih=696 if that helps, I also didn't get the discs for the bottom of the feet which have a sorbothane pad which I suppose doesn't help, so thats another avenue I have to explore.
i have tried different tension on the screws and it doesn't seem to make an audible difference, it just seems that the top cover amplifies the hum, if I hold it I can feel a very slight vibration through the cover, it is a cheap thin piece of steel, once removed it doesn't even hold its shape properly.
Are these two different models?
http://www.audiocostruzioni.com/r_s/...pli%202013.jpg
http://audiophillness.com/wp-content...ps4kklkhrn.jpg
Anyway, I would try to put something compliant in between the top panel and whatever it comes into contact with. You can buy sheets of felt from Hobbycraft for about 50p which might stop one panel chattering against the other.
An alternative approach would be to consider this: is the vibration caused by the mains transformer vibrating, or is the magnetic field from the mains transformer inducing eddy currents directly into the top plate? If it is the former, it might be possible to isolate the mains transformer from the metalwork by sitting it on rubber. They usually have a rubber washer anyway, but examining it closely to see if it can be isolated better by prove fruitful.
Well blow me it worked, this is how mine looks but this is a stock photo
Nice looking piece of kit!
Thanks for that Robert, the transformer is sitting on a round disc of rubber with another on top before the steel washer, so thats already done but it does sit on a steel tripod, I presume to keep the large bottom nut from coming into contact with the baseplate so maybe this could also be a good place to introduce something like your felt idea?
Can't really fit anything like sheet material on top of the toroid without obscuring the top vent, so maybe I'll try Geoffs Sorbothane idea and use an equipment foot if I can find them.
Feet that you use under spikes would seem to be perfect. Are they called spike cups?
Kevin
