If its damping you want, why not make up a couple of bean bags with silica gel crystals. Quite massy and heat resistant. You dry out the crystals in the oven or microwave.
Geoff
Have you tried sitting something heavy on top of the unit to see if that helps Martin ?
The other way would be to try dampening the casing underneath .
Regards
Brian
Amplifier : Sony TA FB740R
Speakers : Tannoy 637
I had a DAC with a mains transformer that was causing a buzz through the top panel. I inserted a small pad of Sorbothane between the top of the transformer and underside of the top panel to quieten things. It worked!
A small slate placemat on top.
It will add mass and probably be thin enough to fit. Easy to remove and will leave no residue.
Kevin
