Page 5 of 6 FirstFirst ... 3456 LastLast
Results 41 to 50 of 55
Thread: Speaker cable survey - does cable matter????
  1. #41
    I'm Phil.
    Quote Originally Posted by Dynamics View Post
    I used epic twin for a while before I upgraded to reference, but I agree not much comes close. The reference beats the twin but reference is not as good value.
    I went to a chord demo at Bristol 2017 and it was clear as day between odyssey, epic and epic reference . Then Sarum was a step up but the difference to the Sarum t (with Taylon) not huge for me. It was a naim/neat system worth at least £20k I'd say.
    People have been challenging me to a blind test on another forum. What I thought I could do is use speaker junction boxes as I don't like the idea of people repetitively swapping cables over and breaking a pin or scratching the back plate of my speakers. This way we could connect short lengths between the amps and one box, put all the cables between the box and another box before the speakers, and then another short length of wire. Or would this mess the sound up such it would degrade the test making it a difficult comparison. I maybe can't be bothered if I can't do that, but I may ask a firm if they would loan me boxes and we'd publish online. That way you'd get continuity with pressing a button.
    It would be a double blind abx test with me selecting tracks and repeating on each track, then they would have to get used to the differences, then I would test them too. What do you think. I may ask futureshop if they would assist with the boxes.
    I went to that demo but found it a bit hard as they played loads of different tracks . I would have preferred one or two track only to tell difference
    Eric Bibb
  2. #42
    I'm Paul.
    Quote Originally Posted by dimkasta View Post
    Well yes it was published 30 years ago
    You are a bit unfair here. Only a part of the article refers to problems caused by unstable wide bandwidth amps. And it is part of the demonstration that things are happening at frequencies above the audible spectrum as amps tend to have wider bandwidths.
    The good thing about technical talk is that it should be easy to pinpoint the subjective parts and try to replace them with objective observations in order to reject or accept them.
    I would sensirely be very interested in further discussing the parts you consider questionable.
    Does it really sound so strange that a pour connection in series with the signal can cause distortion?
    I have seen this many times and the audible effect is not subtle. Never pinpointed the distortion type though . It is the reason why I always both crimp/screw and solder my cable connectors
    Errr...the distortion claim does sound strange, especially as there is no physical mechanism for any "harmonic" or "intermodulation" distortion to occur. That is plain, unadulterated, pure nonsense! I am not in dispute over poor connections and happen to use some very good connectors myself where things are not hard wired.
  3. #43
    I'd also dispute the claims of harmonic or intermodulation distortion, but poor connections can increase contact resistance [and thus integrity], which *can* cause audible sonic degradation.
    At least that's certainly been my experience with both mains and signal cables
  4. #44
    Sonic degradation can only be noise or distortion and technically speaking I think noise is a type of distortion.
  5. #45
    Yes, I agree - and it happens whenever the signal is interrupted or compromised in some way, so attach whatever description you like to the effect
  6. #46
    I don't know. I've yet to be convinced that the type of plug used on a cable is audibly distinguishable.
  7. #47
    Fair enough.
    I've done the comparison enough times now to clearly hear the (admittedly subtle, but worthwhile) sonic improvements gained from, say, upgrading cheap, mass-produced, brass-constructed phono or banana plugs, with high-quality solid-copper or silver varieties.
    However, for best results, the same has to be done on the sockets to which they connect
    The problem is, most folks own commercially produced equipment and don't want to risk 'devaluing' it, fitting different sockets, and often having to drill out holes in cases, in order to get better ones to fit.
  8. #48
    I'm Dimitris.
    Any change in sound caused by exchanging parts is due to distortion by definition.
    We cannot claim there is a merit in using better parts without accepting that there is increased distortion in poor ones (noise, harmonics, frequency attenuation or whatever).
    And such harmonic distortion effects (including intermodulation) on conductive surfaces are real and are even used commercially on industrial real-time surface quality and corrosion monitoring systems.
    Sources: Modified SL1200 MK2, Salas folded RIAA, Phonoclone, VSPS, Shelter 501 MK2, Modified Pioneer P6D6 as transport, Shigaclone transport, Peter Daniel NOS DAC.
    Amplification: Custom 211 Monoblocks, Electrocompaniet AW120, Audio Research VS110, Gainclone
    Loudspeakers: Tannoy Turnberry, PBN Montana EP Signature
    Cables/stands: Tempflex ribbon and Twinax cables
    Other: Promitheus Signature Passive Attenuator, Custom JFET - transformer preamp.
  9. #49
    Yes, I would agree, otherwise the change in sound was imagined. There has to be some form of mechanism (measurable or otherwise) responsible for effecting any genuine change.
  10. #50
    I'm Paul.
    Audible Inter-modulation distortion, and harmonic distortion come to that, cannot be caused by speaker cable connections to binding posts. You can have poor connections and audible improvements may be had by improving the connection. Often I've seen corroded or damaged cable at some soldered joints when repairing cables, and some very poor terminations. Done properly, impedance across most good connections will be less than 0.05 of an Ohm at DC across most binding posts junctions...(yes...I've measured them!) but not enough, unless really corroded or filthy, to make much of a difference. Connector reliability and durability matter far more. Personally, I use Furutech FP 202 connectors because I like them but they do come at a price. Nagamichi spade connectors are also superb and amazingly good value by comparison.
