This is a fully rebuilt Lenco tone arm .
The arm tube is an aluminium cored carbon fibre tube , it has brass bearing blocks , and is rewired with solid core pure silver wires ..
£100 plus postage or can collect ..SOLD
Hi Brian,
Is the arm a GL-75 drop in ?
How is the wiring terminated ?
Thanks
Mike
Hi Mike , yes it is a drop in replacement .
The wires are colour coded for soldering .
I found it better to move the original termination block inside the plinth rather than pulling the tone arm wires up though the metal base .
Solid core is more unforgiving than Litz .. you don't want to be pulling on them in anyway ..
I'm not sure what you have already , but if it is all standard , and you didn't want to move the original termination block you would probably have to extend these wires .. and simple soldering will suffice .
OK, thanks Brian.
