Hi James, I have a few meters of that cable, been sat in a cupboard for a while now. It's industrial cable used in factories etc for fixed installations, picked it up off the bay for considerably less money. The reason I've not used it, is it won't fit any of my plugs, the entry holes are too small and the cable cleat wont fit, I find 10mm OD is about the maximum that you can use and some plugs wont take that. I won't pay exotic prices for plugs so it has to be something readily available. Having said that, the Chinese have latched on to this lucrative market and are starting to copy items. I saw such a copy recently on the bay, a copy of an £80 plug for £4.50 including postage from China, you probably know the type, IEC mains input plug with a transparent Blue nose and Black body.
From memory I think this cable is getting on for 14mm OD, my MIG welder uses thinner stuff.
What's the thinking behind the 4mm square copper?
Always willing to here a good case argued.
My kettle draws eight times more current than my whole music system put together and that runs on 1mm square, so I'm interested if you have any information that has convinced you its worth while beefing up the leads to this extent.
"Power amps into separate wall sockets and preamp and TT from Mains block."
I think I understand your reasoning in this approach, but it does go against what would be recommended to avoid ground loop issues, so may not work for everyone. Suck it and see situation.
You going to NEBO this time round?
