I have various sets of headphones- just looking for something to use with my IPhone 7 during my lunch break if I go out for a walk.
Budget probably up to £150
Need to be wifi i guess robin... i take it ios new phones are still not out? Ive a set of sony bluetooth ones that are overear/ on ear type but seperate at same time. They are good. You can use them for a while if you want. I dont need em currently..just fitted new covers
If you don't need bluetooth, I can highly recommend HiFiMan RE-600 Songbird IEM Earphones
Rob.
Powered by crossed fingers and clenched buttocks
If its an iphone7 it doesnt have a jack socket. The airpods seem to be available...in 6 weeks wait apparently £159 though.
So in summary then the apple iphone 7;
No replaceable battery, no SD card slot, and now no 3.5.mm socket...which leaves you with blue tooth, so I was going to suggest that a pair of aptx compatible headphones would be best, except it would appear that apple refused to adopt the protocol...
I'm sure beats will be coming out with some overpriced compatible solution soon...
Just spotted you have an 3.5mm adapter, so I'd suggest a pair of Soundmagic E80s, excellent VFM & SQ
https://www.amazon.co.uk/SoundMAGIC-...soundmagic+e80
Cheers, Will
There is an adaptor lightning socket - 3.5mm jack.
Hunter S Thompson
