Hi all
As per the thread title my sr370 need new feet, any ideas?
Thanks in advance
Nick.
I'm Nick.
Hi all
Thanks in advance
Nick.
My advice is plentiful on this subject lol
First off - try and get a spare SR370 for parts. They work better than anything else I tried.
Second option- Isofeet are very good to but you will have to manipulate the TT because the threads are different sizes. I used thread converters. Glued them into the holes where the original threads are and all went well. Except for the super glue running and ruining the TT. Walpurgis has a better, non run solution.
Put a longer bolt through the feet too otherwise the TT will rest on the foam.
Very good sounding solution though.
Third option - worst
Get something like this
Look at this on eBay http://www.ebay.co.uk/itm/302218931129
Put a bolt through and you're done.
I found the lack of spring/suspension/damping did affect the sound but a return to the original feet cured this.
Hope that helps.
Here's my thread on this subject
http://theartofsound.net/forum/showt...eet-help/page5
I'm Nick.
Thanks for the advice Oliver,
Will try to repair original feet, my stupid fault, tried adjusting height with
Turntable Insitu and managed to snap rear foot of by turning it the wrong way
Oh man. I may have a rubber insert if that'd help ? Not 100% sure though. I'd have to have a look
I'm Nick.
That would be much appreciated Oliver, thanks.
Nick
I can't look until after 22:30 as I'm at work but I'll let you know.
Recommend and use screwed in RDC cones on my Technics
Mike
I'm Nick.
Thanks Geoff and Mike
Looked at the techie feet and yeah possibly not strong enough also I think the thread diameter is different, the sr370 uses an m4 thread.
Re the cones, it's the height, the original feet are 35mm high.
The only thing I've found that fit the bill are spikes and moulded plastic furniture feet, and I don't Think I could live with the look of either of em.
