Results 1 to 10 of 10
Thread: recommend a speaker surround glue
    Default recommend a speaker surround glue
    Can anyone recommend a good speaker surround glue please...for rubber..kef b200 drivers to be precise cheeerz..
    'ANDSOME IN THE SUMMER..'ORIBBLE IN THE WINTER. Barney Milne
    Cambridge Audio CXN, Seagate nas drive, Michell Gyrodec SE, SME309, Benz M2 Ruby cantilever, Denon DL103, Primare R32, Densen D20, Densen D30, Cambridge Audio 840A V2 integrated, Pioneer SX-N30AE Network Stereo Receiver, Roksan Darius speakers, Technics speakers, Canon speakers, Bastanis Dragonfly Horns, REL Storm III sub, Target R1 speaker stands, Atacama Equinox.
    I'm Adam.
    Standard PVA is fine.
    I'm Ken.
    Quote Originally Posted by Beobloke View Post
    I would be surprised if PVA had very good adhesion to Rubber.
    Its a water soluble adhesive that likes a porous surface to get into, Wood, Plaster, Cement etc.
    It peels off flexible plastic surfaces quite easily and I would have thought the same for Rubber, whether natural or thermoplastic.
    I use polythene bags between surfaces I don't want to stick together, with PVA that oozes out of clamped joints etc. They pull away from the set adhesive quite easily.
    Shoe goo is good. Sticks to most things.. available on amazon etc
    As always, I recommend Aleene's Original Tacky Glue. I've done many speaker repairs with it. It is water based and allows joints to stay movable for a while, long enough for you to be sure positioning is correct. http://www.ebay.co.uk/itm/ALEENES-OR...IAAMXQUmFSmxeQ
    This adhesive is also perfect if you want to experiment with doping. Paint it on and once dry, you have the same type of slightly glossy, semi tacky surface coating as found on many drive units.
    Ive got her very tacky glue for extra tackyness
    I'm Nathan.
    I always use contact cement. The shoe goo is a really good idea. I've never thought about trying that.
    Sent from my Z981 using Tapatalk
    Quote Originally Posted by nthall View Post
    Shoe Goo is also a contact adhesive I believe. They do work for speaker surround repairs, but can be tricky, as they grab and if you get the surround in the wrong position and want to repositions it you can have problems. As I've experienced. That's why I use a water based adhesive now.
    I'm Nathan.
    You have to be committed with contact cement. I've had problems with I too, and it's not easy to fix if you don't notice right away. I'm probably just being stubborn because I like the smell. I've shoe goo for it's intended purpose.
    I'm Nial.
    Seconded...great glue for speakers.
