What you using ?
Is there anything like this for audio http://www.ebay.co.uk/itm/Motorcycle...jc3Y7ewnTQ34vQ
What you using ?
I'm gone.
get those car accessory items cryogenically frozen and you can use them for audio cables
Thanks but I was thinking something more along the lines of the link post #1 as in separate \ keep apart not hide
I'm using an ambient spacer system, or air as its otherwise known. One of the joys of a simple setup being that I don't have a rat's nest to tidy.
Cable dressing... I just try and keep a few inches between the power and the signal ones. No power to the pre so only the power amp and source cables to worry about.
Being me I've deliberately tried runing them next to each other to see if I could notice any deterioration. I thought I could but I'd hate to try it blind. Still, it is best practice to separate them.
Helps if the amp has the power socket centrally placed, designers please take note,
hard to tell what mine re doing as I cant see round back of them. but looks a mess. Think I once tried to make them tidier and hurt myself lol so they are what they are nowadays. dont have any problems anyways
Might do the job...............................
http://www.nordost.com/sort-systems/sort-lift.php
Jim
. bulldog clips.. cheap and work
