Hang on though, if you're tracking a vertical modulation, it's out of phase anyway, isn't it?
Time flies like an arrow.
Fruit flies like a banana.
Ideally excellent channel matching and RIAA accuracy between channels for best results so a SS phono stage with feedback incorporated is ideal.
I've had some luck with Fozzie on a few turntables. 6 guys in our local audio club chipped in for it, and we pass it around as needed. The test LP is a must, I'd suggest staying away from changing wiring just to use it. Results are different for every cartridge, so occasionally you wonder if everything is working correctly. I suppose I'm happy to have it especially for only a fraction of the cost, but if I was buying now, Adjust+ would get serious consideration. FWIW, I used it for years with VPI unipivot arms and that never caused a problem.
Sota Star Sapphire V turntable, SME V, Dynavector XX2, MkII MC cartridge, Nagra BPS battery powered phono stage
Digital: Server Synology DS415+ / Sonore microRendu / Schiit Audio Gungnir Multibit / Custom Linear Power Supply by Ecco Audio
Both: BAT VK51SE > Krell FPB-300 amp > Sound Lab A3 ESLs > 50 yr. old ears(left-handed)
I'm Slav.
Problem with Fozgometer is it does measure crosstalk only , in many cases phase intersect at very different azimuth setting , vta has massive impact on this . I've been using Adjust+ for some time and can recommend it highly , home versions offers as well wow& flutter , freq. response and tonearm/cartridge resonance measurements , it's bit fiddly , you need good soundcard (24bit/96kHz) , you need to calibrate soundcard and input signal but once you've done it the difference is easily perceivable.
