Not doing too much in the way of hi-fi at the mo as the house and slot cars take up most of my time.
However, someone on our local Google group asked me to try and fix a record player for him last week. Horrible floppy linear tracking arm but a decent DD motor. Incredibly complicated computer controlled everything, track choosing, special tape out etc. Presumably built after CD came out to try and replicate some of the functions. Just more to go wrong then.
Spent ages trying to get the thing to work but all the usual physical things didn't work. In the end I checked few voltages (proud of me Alan?) and in several places, where there you have been volts, there weren't!
He said keep it for spares then.
Had a play with the motor and 12V across a couple of points made it go round and at the right speed too!! So, another project in the offing. I've wanted to have a deck dedicated to our parallel tracking arm for some time but lacked a decent motor unit. Tested this morning and it sounded great. As usual with parallel trackers, the bass is absolutely clean and voices have a real sense of life. This with a cheap Sony cart without the arm properly sorted.
High quality DIY in progress as you can see One of Alan's (Firebottle) external power supplies which apparently is a required improvement for DD decks. I suspect that 10 amps might be adequate. The LEDs say it draws at least .1!!
Anyway, now to design a decent looking TT to add to the collection. Just as I was thinning it out too.
100_7896 by Gordon Steadman, on Flickr
