Results 1 to 10 of 14
Thread: New radial- is it worth it?
    Default New radial- is it worth it?
    Thinking of putting in a radial from the fuse box to my hifi but is this really going to give me a cleaner supply than the ring main when all electrics go back and through the same fuse box?
    Sorry I was out earlier.
    I imagine from knowing your set-up that when you are listening to the stereo there is very little else that is powered up in the house.
    Now that you have gained the extra transparency from the change to monoblocks I doubt very much that you will benefit from installing a radial.
    I'm inthescottishmafia.
    Could try a balanced transformer instead?
    Hunter S Thompson
    It certainly wouldn't do any harm. When I redecorated my living/listening room I had a dedicated ring main installed, consisting of ten double sockets fed from a separate RCB/MCB at the meter. I did this as I dislike having cables running around the room, even if tucked close to the skirting board. Since I use electrostatic speakers which need to be powered, as well as monoblock power amps located immediately behind the speakers, the extra sockets were needed.
    Has it made any difference to the SQ? Not in my opinion, but the neatness of the cabling for my audio system gives me peace of mind.
    Thanks chaps, may have saved me a lot of time and money! Might just put some more sockets in and be done with it.
    BMT does sound a interesting prospect and would certainly cure the buzzing in my Croft transformers!?
    I had a radial circuit installed for my downstairs AV system, mainly for convenience of connecting up, but was curious if it made a difference? Thought it maybe sounded a little better but what did make a difference was checking and tightening up every connection in every socket in my house, especially the earth, painstaking process but worthwhile for safety reasons also.
    Chris
    Hi Chris,
    Good to see you back. Hope you're keeping well and your system is sounding good!
    Hi Chris,
    Thanks Marco , not too bad, my system is almost there but I think a change of cartridge will do it.
    Chris
    Nice one. Hope it works out, and if I can give any help or advice let me know
    Thanks, yes perhaps look at old threads about cartridges.
    Chris
