Results 1 to 4 of 4
Thread: RTEVIEW - APTITLIG Board - A quick way to improve your deck for £15.
    Default RTEVIEW - APTITLIG Board - A quick way to improve your deck for £15.
    I bought one of these http://www.ikea.com/gb/en/products/c...la%7C%7C%7C%7C and tried it under both my Lenco '75 and my Technics 1210 to great effect. It seems to have been especially designed for 1210 users as it's a perfect fit for the decks footprint. I have included a few notes with regards a couple of albums that I use for review when assessing new upgrades to my kit. I hope this proves useful to someone out there. I used my 1210 reference deck to evaluate the board. My deck has the following modifications and is by no means "stock"
    DECK
    Technics 1210 mk 2
    Isolation Board
    Aptitlig butchers block
    Mat /Puck
    - Analouge studio crysal mat
    - Pure Cu 1.2kg record weight
    Platter
    - Mike New Copper/Aluminium
    Bearing
    - Mike New
    Chasis
    - Silicone dampened
    - Mike New Baseplate
    - Filled and stiffened
    Tonearm board
    - Magna Audio ebony armboard
    Feet
    - Isonoe
    PSU
    - Paul Hynes SR7EHD-27XL/DCSXL Ag DC lead/Jaeger(low-impedance) connector
    - Custom built power lead
    PCB mods
    - Paul Hynes 3 Stage Regs
    - Recapped and optimised PCB
    - Pitch slider removed
    - Cue light removed
    - Strobe removed
    - PSU removed
    - Internal silver (2mm solid core) rewire + teflon dialectic
    ARM
    - SME V
    - Kondo Ag Rewire
    - Kondo Ag cartridge tags
    Cartridge
    - Ortofon Cadenza Black
    Cables
    - Yannis SPD-4 IC Tonearm + Eichmann Ag bullets
    - Shielded earth + gold plated earthing
    Records Used
    IRON MAIDEN
    POWER SLAVE The Rhyme of the Ancient Mariner - 2015 repress from analog tapes.
    This is a track that I know backwards, forwards, and any angle you choose to mention. I instantly noticed more authority to Nicko McBrain's drumming
    especially with the bass drum, further into the track I noticed area of delicate triangle work that had previously been lost. Steve Harris's bass gained
    a little more authority and I could hear further into complexities of the track than before as I realised I was picking up clues to some of Steve's more
    delicate work on the frett. I'd thought I'd heard glimmers of this delicate frett work before but now it came to realisation and was not my imagination.
    Overall the improvement were subtle but enough to put a smile on this old mosher's face.
    MARILLION
    SCRIPT FOR A JESTERS TEAR - The whole of side A!!!! - 2014 repress
    I immediately got the impression that the speed of this album seemed to have increased and then I
    realised the impact and speed of delivery of the actual tracks had tightened up quite considerably.
    This came across as a great precision to the delivery of the drum and a greater snap to drum
    strikes. Fish's vocals seemed to have cleaned up a little whilst singing Chelsea Monday. The upper
    treble ranges of Steve Rothery's guitar work seemed to have better definition and appeared to reach
    new highs. I've always used this particular record as a tester for sibilance and true to form it was
    still apparent using the Ikea chopping board but quite nicely improved.
    The deck as it looks now
    Conclusion
    I always classify a new modification a sucsess if I can hear new information on my old reference pressings. The boards can be picked up fairly easily so I'd suggest buying one and seeing if it can help you vinyl replay source.
    PRE
    I'm Brian.
    This is good work as ever Andy and I'm sure it will benefit all the turntable users on the forum , not just the Technics guys . At the end of the day , though , it's for your own benefit and I'm sure you're sitting there with a nice dram and a smile on your face
    I haven't got around to getting the chopping board yet as I've been playing around with my digital system which is sounding very good at the moment due to some changes which I have made . I did buy a Shure M75ED fitted with a Jico SAS stylus from another forum member , but I haven't really had the time to listen to it properly yet . The chopping board upgrade is still on my radar and I have it saved in Ebay .
    Regards
    Brian
    Amplifier : Sony TA FB740R
    Speakers : Tannoy 637
    I'm Neil.
    Damn!! I've been down Ikea this evening, could have picked one of these up, just measured my Lenco and it would be a perfect fit.
    Do you have anything under the board?
    Ah! So you've gone up another level with the Shure! I originally tried the chopping board under the Lenco and noticed an improvement. I have two thinner boards which now live under my phonostage and preamp. I'm not sure if they help improve things but they are now taking up less space on my floor and do offer another level of isolation from vibrations from themselves upto the deck through the hifi rack.
    Quote Originally Posted by Shadow Moses View Post
    Here is the original article which might help. http://www.theaudiobeat.com/blog/ikea_aptitlig.htm
    PRE
