Page 1 of 3 123 LastLast
Results 1 to 10 of 29
Thread: Flat records...
    I'm Adrian.
    Default Flat records...
    Am I alone (and anal) in checking every album I play with a bubble level where the stylus passes?
    Although the SP10, arm and cart are level (azimuth corrected) most albums are not flat as they pass under the stylus, usually running up a few degrees to outer or inner depending on pressing. To correct this I use a small circular felt spacer that fits around the spindle and different arm pucks of differing weights to level things out. This works in 99% of cases.
    Weirdly older, thinner vinyl is the least variable, warped occasionally but typically perfectly flat.
    In perpetual pursuit.
    Technics SP10 mk2
    Miyajima Shilabe cart
    Hashimoto HM-X SUT
    The Truth linestage
    Cary 805c SET amps
    Audio Note ANe-SPX speakers
    I sure don't lol
    Neither do I!
    I'm Adrian.
    It's just part of my routine... Ok I'm anal.. rolleyes..
    Technics SP10 mk2
    Hashimoto HM-X SUT
    The Truth linestage
    Cary 805c SET amps
    I'm Robert.
    My analness (for want of a better 'word' ) is not as extreme but yes, I do obsess about my records being flat. I can't abide warps and the flatter a record spins the happier I feel - sad but true
    That's probably true about all of us vinyl spinners. But I don't check each LP with a spirit level!
    A degree or so out of level, really won't make much difference.
    I'm Robert.
    Absolutely not
    It's very important for any warp to be gentle rather than abrupt. An abrupt warp will cause 'scrub flutter' by the stylus, a phenomenon exacerbated by short arm stubs as used on tangential tracking arm designs.
    A gentle warp of 1-2 mm, measured at the record's rim, is unlikely to cause any problem.
    Biggest problem with many new records seems to be slight dishing
