Originally Posted by
eddieedwards
Thank you Geoff, that's a very kind offer.
I suppose I'm asking why are some speakers considered valve friendly, or solid state preferable, when they appear to be similarly specced in terms of impedance and sensitivity? There must be more to it than meets the (non technical) eye!
Indeed there is... Much depends on what the valve amp is. Big push pull ones with plenty of feedback can be expected to drive pretty much anything ok. Examples are the likes of EAR 509, 519, Radford STA100, Papworth M100 and several Audio Research and Mcintosh amps. IE the more SS like measuring ones with plenty of power. At the other extreme are the likes of SET's with often only 8-15WPC output and a high output impedance. The lack of power obviously requires high efficiency speakers in order to get the required volume from so little power. The high output impedance means a poor damping factor (to over simplify a little, the ability to "grip" the speaker cone), which means speakers with good "self damping" properties are best. The high output impedance also means that the frequency response will tend to try and follow the impedance curve of the speaker so speakers with a fairly flat impedance are best.
Between such extreme examples are the many 15-30WPC mainly push pull amps with moderate feedback. As you would imagine speaker requirements are a bit more relaxed than for an SET, of course it could easily drive any SET friendly speaker, but would also handle ones with a bit lower efficiency and rather more awkward load. In this category are so many different models that, well, it's gonna have to be down to those sound detectors on the sides of your head!
