Page 2 of 2 FirstFirst 12
Results 11 to 19 of 19
Thread: cleaning a stylus ultrasonically
    I'm Spencer.
    Quote Originally Posted by Spider View Post
    The sponge
    +another one
    Sota Star Sapphire V turntable, SME V, Dynavector XX2, MkII MC cartridge, Nagra BPS battery powered phono stage
    Digital: Server Synology DS415+ / Sonore microRendu / Schiit Audio Gungnir Multibit / Custom Linear Power Supply by Ecco Audio
    Both: BAT VK51SE > Krell FPB-300 amp > Sound Lab A3 ESLs > 50 yr. old ears(left-handed)
    I'm Tim.
    The sponge
    - Cart Denon DL-102 in bakelite Ortofon SPU 'G' type headshell
    - TA SME 3009 'Improved' converted in heavy mass with detachable headshell
    - TT Thorens TD160 'E' totally tweaked driven by an 'Eagle & RoadRunner' PSU & tachometer combo
    - Matts top to bottom: leather, cork, felt & 12" vinyl
    - Pre-amp 'Modulis' Isem
    - Amp 'Exampli' Etalon 2x40W
    - Speakers 12" Leak 'Sandwich' first generation creatively recapped
    I'm Simon.
    Zerodust is the one. I also use the ''green paper'' every 4-5 albums, just gently to get off any stubborn gunk.
    I'm keith.
    I thinks it's a magic eraser pad for me!
    thanks to everyone for their reply's - seriously good and most welcome advice.
    I'm Neil.
    Quote Originally Posted by hagzo View Post
    To be safe, use it by lowering the tonearm onto the pad, up and down, rather than dragging the pad across the stylus. Whilst I didn't have problems, I was using a spherical stylus at the time, line contact stylii for example could shear off.
    I'm Matt.
    For no particular reason I tend to alternate between the ubiquitous Green paper, an AT vibrating cleaner & sometimes the Onzow zerodust gel pot.
    Currently thinking about getting a proper vacuum RCM as well. Even some of the brand new LP's I buy look like they could benefit from a proper clean.
    I'm AMusicFanNotAnAudiophile.
    Chris
    Common sense isn't anymore!
    Quote Originally Posted by Manicatel View Post
    An RCM is well worth having, especially if you have more than say 200 LPs in your collection. Even brand new LPs benefit from cleaning, if only to remove excess stamper release agent.
    As regards stylus cleaning, I use a Goldring electronic cleaner with a carbon-fibre bristle pad.
    I'm Rob.
    Stylus cleaning becomes much less of an issue, the cleaner your records are.
    Rob.
    Powered by crossed fingers and clenched buttocks
