Jon
A person who never made a mistake never tried anything new.
Set up
Lafayette el84 power amp , Audio note M1 pre , Tannoy Sterlings, Garrard 301 , SME 3012 , puresound P10, Ortofon SPU, Cambridge CXN streamer
Micro mega Duo 3 cd transport ,
I'm ChrisB.
Love it, love it, love it!!!!
It's in need of a little work at the moment, plus it looks like a bag of old spanners, but when it's playing, it's just sublime. One of the few truly great vintage amps.
Thats what i've heard Chris, if it needs componant work you can drop it into mine when your next down and i can get my man to sort it out for you if you like, he has done one recently but i missed the chance to have a listen, i have also been tempted by the SP8 pre but they don't come up that often, my man is getting me a Audionote Zero pre for me to try they can be tweaked a bit and they are cheap
Jon
Set up
I have a Zero dac which I've tweaked a little.Very nice.
I have heard that the Zero range cost to much to make and sell at a profit at the price point it was aimed at but sounded very good as a system,(i very nearly bought one)the mono blocks suffered from over heating becuase of the size of the case work, this can be helped with a pc type fan being fitted to help extract some of the hot air.
I have listened to their OTO intergrated SE a very nice sounding amp only out putting 9 watts but matched with Tannoys it sounds amazing.
I do like their stuff but not their prices
Jon
Set up
I'm Paul.
The thing is with attenuators is that they are passive and you have to consider the output impedance of the source and the input impedance of the receiving equipment as well as cable capacitiance.
The problem with most valve amps is that the volume control is effectively a passive pre amp before the amplifing circuitry. This means that the input impedance tends to change with volume setting. Sticking another passive attenuator infront of a passive attenuator can lead to problems such as that mentioned above.
Its horses for courses as usual.
~Paul~
