Page 1 of 6 123 ... LastLast
Results 1 to 10 of 60
Thread: Ikea Kallax etc
    Default Ikea Kallax etc
    Anyone know for sure if these box systems fit 12" records ok. Is there any others around same price that are worth consideration. I wanted to have some of my music out for playing as I struggle to get them out of the boxes they are in at moment any info gratefully received
    Grant ....
    OPPO BDP-103D DARBEE - JBE SERIES 3/B&O SP1/EMOTIVA XPS1/12V BATTERY - TWIN PRO MONOBLOCK AMPLIFIERS - XIANG SHENG DAC\PRE\HEADPHONE AMP\WE TUBED - TWIN AVANTREE OASIS CLASS 1 BLUETOOTHS - AUDIO TECHNICA ATH-MSR7 & OPPO PM-3 PLANAR HEADPHONES - WIN10 JRIVER24, SPOTIFY - SMSL M6 MINIDAC - RPI/AUDIOPHONICS/5V BATTERY - FULL RANGE TWIN TELEFUNKEN/Q ACOUSTIC BT3/CANTON SUB - P.INSPIRED MAINS REGENERATED.
    I'm Charlie.
    Grant,
    I have just checked. We have both Expedits and Kallexs at home. The internal dimensions are near damn identical - LPs and box sets will fit in fine.
    Charlie
    I'm Simon.
    Yep, they are the perfect size for LP's (it's Kallax btw). I've got 2 of the 8 square ones (well 1 of those is the older Expedit, but they are the same size internally). Don't think there is any alternative at this price point.
    Thanks Charlie and Simon... yes I noticed I mis spelt doh!! Ok I wasnt sure as they dont give internal dimensions. A single 4 or 6 will do me I think. I have limited room and need them at a decent height as I cant get down too low now. Currently in the ali boxes Ive always kept them in.. great stuff, at least i know they will fit.
    Grant ....
    I'm Nathan.
    The kallax is perfectly sized for records. The need to be braced in my opinion. I had one for a while, and it didn't feel sturdy enough to trust my albums with. I braced it, and it worked fine. I ended up replacing it with shelves I built myself that fit the walls perfectly. There are plenty of other options, but they are a lot more expensive.
    Amazon sells some double cube ones that aren't very expensive, that seem more stable. I have some stacked two high, that make a good base for setting some gear on too.
    Sent from my Z981 using Tapatalk
    tHANKS.... iVE SENT AN EMAIL TO THE LASS. hOPEFULLY SHE CAN GET ONE FOR ME SOMETIME WHEN SHE IS OUT AND ABOUT IN eDINBURGH.
    excuse the caps
    Grant ....
    excuse the caps
    No!
    No!
    i see youve changed sex buddy
    Grant ....
    Like the new look?
    I'm Nathan.
    Looking good!
