I can endorse the Nuprime STA-9 amp. I have two configured for monoblocks operation. As good as the STA-9 is in stereo mode (it actually drove my Magneplanar 1.7 speakers very well which is no mean feat) it is a very different amp in monoblock mode. Not just louder and with better bass extension and control, but a more etched sound with better detail resolution. The already low noise floor completely disappears in monoblock mode. I also considered the ST-10 integrated which I heard on a trip to the USA just before Christmas but still prefered the two STA-9's which are about the same price. Another advantage I have found with the STA-9s is that they respond well to using XLR balanced interconnects with very short speaker cable runs.
Geoff
Bump. Anything out there?
I'm andrew.
PM sent.
I'm gordan.
Did Nuforce/Nuprime sort all the DC leaking issues they had in the past?
Gordan.
Speakers: Oris Swing MkII
Amps: Thomas Mayer 300b/ Hiraga La Maison de L'Audiophile 20
Preamp: Silver AVC by eng. Ferenc Lazar
Phono Preamp: Shishido LCR by Solaja Audio
Decks: Garrard 301 Martin Bastin reworked/plinthed with Fidelity Research FR64fx
Garrard 401 in eng Ferenc Lazar solid wenge plinth with SME 3012/2
Cartridges: SPU Spirit/ Koetsu Black revisited by eng. Salai/ Miyajima Shilabe
Step Up Transformers: Tango MCT 999/ Ortofon T-5000/ Lumiere SUT
Digital: Shigaclone by eng. Ferenc Lazar with Lampizator Amber II
Wires: of sufficient length
I'm in the process of trying to send back the STA-9 ... unfortunately there's no way to listen to the ST-10 in the UK on demo, or to get hold of another STA-9 to try the twin monoblocs, without acutally making a purchase. I'm reluctant to shell out the difference in cash, in the absence of a dealer prepared to put demo kit where their mouth is .... so back to valve amps.
Sad as there's a possibility it might well have been the way forward - the STA-9 remains a bargain for £700, and I stand by what I said about it being better than some £5k valve amps, the musicality and ambience is very good indeed though it lacks ultimate detail which is why I was trying to hear the ST-10. If Nuprime are serious about market development then they need to have dealers with demo kit in the European geography.
Anyway - to be frank - I am sorry for what I posted above, I had no idea the Belgian dealer would play it this way - he doesn't seem to have heard of the EU distance selling regulations, so I'm struggling for a refund. I definitely take back any recommendation!
John am I correct in saying that the Tannoy 15" HPD385s are rated at about 92dB?
If so I cannot see why they need so much power... maybe they are a tricky load for the amp for some reason or you have quite a large room..
Otherwise I would have recommended this Audio Note amp which is about 10w: http://www.ebay.co.uk/itm/Audio-Note...4AAOSw2xRYjPam
Bev
Trust me, won't do the job at all ... Tannoy 15in DCs (especially the HPDs) need a fair whack of current up them (and a decent damping factor) to control those 15in cones. HPDs in particular have extra mass in the cone that Monitor Golds don't have. Single ended amps (which usually have bugger all damping factor), don't cut it at all, 10w push pull (like the Audio Note) will drive them but sound no better than 'ok'. I would say a minimum of 40w push pull .. the ideal here is a 70w KT88/KT90 amp, anything short of that while it might sound pleaseant enought will NOT cut the mustard with 15in HPDs.
