Have you got a spare cart ?
Have swapped the RCA plugs over in the amp and the drop out changes sides so I guess that rules out the amp? Did have a budget AT91 but broke the cantilver putting it in a box , so no unfortunately. I have been thinking of trying another cart so maybe my hand is forced and the time has come!
Sadly not. All of my London based compadres are digital loving folks. Might get a cheap back up AT95 or something similar to see if it is indeed the cartridge. Then maybe something nice will come up on Private Exhibitions. Thanks Oliver.
Loz
Hi,
I have an (old but OK) AT-91 I would be glad to lend you so at least you could rule out the Cartridge. I don't use it any more and keep it just for such occasions should I need to check anything out.
PM me your address and I'll post it off as soon as I get the chance.
Jim.
I'm bob.
Like you suggested, switch the tags on your cartridge and see if the problem switches sides
Switch (white with red) and (green with blue)
If the problem switches sides then you know for sure that it is time to buy a new cart.
This is such a nice forum.
Advice is given without a sneer and people go above and beyond to help out someone they've never met.
I have a lovely warm feeling (though that could be the wine).
See, not everything in the world is shit.
And exciting times for Loz - he get a new toy
