Apologies it is 6mm not 3mm. Good call but not sure if it will strain the motor as I have been using it like this for a while. The only problem I find with out the weight it's hard to clean the record as it slips on the glass with out it.
I'm Con.
Thanks Guys will be ordering the mat in the next few days. CHEERS.
As this baby will attest to
http://giphy.com/gifs/turntable-kGXFhyYbaHIe4
I'm Con.
Love your work mate.
I'm Mel.
On the point of the lip on the platter - I have cut a lovely round circle of leather from a carefully selected new wash leather (consistent thickness and smoothly dressed). It's just thick enough to raise a larger solid platter mat above the lip and leather is often thought to make a good platter mat. It works very nicely in combination with my Funk Firm Acromat and I also use a spare Michell clamp to good effect.
Mel
I'm Mel.
I tried numerous mats under the crystal mat and came to the conclusion that they took away a lot of microdetail when used in combo with the crystal mat. These mats work best with metal. Why do think microseiki and other Japanese companies used glass and metal in the first place?
I'm Con.
Hi guys just received my glass mat and got 15min to try it out . 1st thing is that It came excellently packed well done to them. Now sound wise ,I should mention that I am using the stock platter and has the DYNAMAT EXTREME modification . My fist impression is very positive ,the sound got clearer which brought out more micro detail,basically every thing was more detailed with more realism,my only nitpicking is the bass was oh so slight boomier than the rubber mat but at the same time still tight. I am quite pleased with it as it is definitely an upgrade from the stock 3mm rubber mat, l recommend this glass mat without hesitation,great upgrade.
Technics SL1210 MK2 fully rebuilt and repainted. Ortofon 2M Black Cart, Isonoe isolation feet , MN bearing and Funk Firm platter upgrade, Oyaide RCA Tone Arm and speaker cables, Jelco SA-750D Tonearm. Oyaide HS-TF Carbon headshell, MCRU Linear External PSU, High Fidelity Crystal glass turntable matt, Blue LED upgrade, Denon AVR-2808CI Amp, Bowers and Wilkins DM602S3 Speakers,
Black Rhodium Jazz power cables for amp and turntable, Firebottle mk2 Phono Stage.
