Originally Posted by
Infinitely Baffled
Hello, Tony. Arkless Electronics, who have a trade room here on AoS, have developed a highly regarded phono stage which uses your Cambridge Audio stage as a "donor" unit. My understanding is that it is rather more than an upgrade of the Azur 640P. It is in effect a redesigned phono stage which uses the Azur as a basis. I don't know whether part of the Arkless spec involves a higher gain than the original donor unit, but my guess is that if you speak to Jez Arkless, he will be able to incorporate that specific requirement, if it is not a standard part of the redesign. I would have a word with him, if I were you. Good luck in sorting the problem.
IB
Cheers Gary
The OP rang me yesterday actually for advice on this and we discussed this option.... I also suggested that he could take the output from his pre amp (the main outputs, not the tape outs which he was trying to use) and thereby, assuming the line stage has gain, boost the output from the phono stage to a suitable level.
The Arkless 640P has much higher output than the standard one (an AOS member with one on order has actually asked me to reduce the gain a bit on his!) at 64dB but I can customise for any gain at no extra cost.
This would vastly increase the quality of the sound as well of course! Much more so than a better sound card!
