Anyone selling a Power Lead with IEC connector. Something better than a kettle lead!
How long?
Ok folks Power Lead now sorted as an AOS member has kindly offered to make me one.
I'm stuart.
Think 'Pieoftheday' and 'sumday' should read this http://theartofsound.net/forum/showt...SE-READ-!!-***
OK, I'll bite on the blatant thread crapping.
The substation isn't part of the loop that a component "sees". It's an absurd argument that electrons travel or "wiggle" through our components, into plug sockets right through to substations.
Some equipment is transparent enough to make cable changes audible, some equipment is cranky with certain cable characteristics, and some people are silly enough to make blanket assumptions.
Power leads make as big if not a bigger improvement than interconnects and speaker cable. I've lost count of the number of people who once were of the opinion, 'they make no difference' and now there whole system is using quality power cables. If you are happy with your kettle lead, all well and good, but without trying you should not put down.
I have to agree with that. I think it's the quality of the shielding. Standard mains leads leak a lot of electrical noise. That's why as a network engineer, we'd avoid running network cables in the same conduits as mains cables. I'm sure that one of the main gains from using good quality leads is the avoidance of electrical noise from one cable, affecting the signal passing along another cable.
Rob.
Powered by crossed fingers and clenched buttocks
