Page 50 of 54 FirstFirst ... 404849505152 ... LastLast
Results 491 to 500 of 533
Thread: Wasn't gonna post this...
  1. #491
    . Ted reasoned that if differences in RF can degrade the sound, then RF can be modeled and shaped to improve the sound.
    Was this Big Ted or Little Ted?
    What was Hamble's input?
  2. #492
    RothwellAudio Guest
    If anyone wants to read the rest it's here:
    http://www.synergisticresearch.com/a...cs/atmosphere/
    BTW, this is the bit where it goes off the rails first:
    "...and came to the conclusion that man-made and solar RF must play a significant role." Must? Why must it?
  3. #493
    I'm Simon.
    assumptions make an ass of you and me.
    Anyone with half an ounce of knowse and recourse to graphene electrical resistivity measurements knows you can't make a fusible element out of it, it's too conductive, the different between a 1amp strip and 100 amp strip would be tiny. Also they need to connect it to the end caps and that requires mounting to metal and soldering. Maybe they roll a bit of fuse wire in charcoal dust but I do not for one naosecond believe they use graphene as the conductive/fusible element. It's just bullshit, as is their obfuscation of any reasoning behind the design.
    If you can't see that the marketing babble is just there to lead to the phrase 'night and day difference' by the use of relatively sharp NLP then you deserve to be fleeced.
  4. #494
    At one of the NEBOs Les from Avondale gave a little talk where he explained how he 'voiced' (although I don't believe he used that exact term) his power amplifiers by using certain types of components i.e resistors etc of different construction and materials, and he likened this to a chef adding herbs and spices to a curry.
    And it's an apt analogy. Building a musically realistic/rewarding piece of equipment is akin to blending together a collection of 'flavours', in order to create a successful recipe. It's a process that applies to both chefs and audio designers
  5. #495
    Anyone with half an ounce of knowse...
    What language is that, then? Not sure if I need any "knowse", but I'll take half a pound just to be polite
    Did you mean nous?
  6. #496
    montesquieu Guest
    Here's some "info" from the website of one the fancy fuse manufacturers (about one of their other products):
    "So we began researching variables that could contribute to the mystery of midnight vs. mid-day system performance and came to the conclusion that man-made and solar RF must play a significant role. This led us to research of factors that contribute to fluctions in the Earth’s ambient RF environment. Ted reasoned that if differences in RF can degrade the sound, then RF can be modeled and shaped to improve the sound.
    There are three major disturbances on the Sun that affect radio propagation here on Earth. Solar Flares, Coronal Holes, and Sudden Disappearing Filament (SDF). Each disturbance causes both electromagnetic radiation and ejection of material from the Sun that alters RF on Earth. What we looked at was how each of these disturbances affects our RF environment during the day vs late at night with the intention to mimic late night conditions to improve sound mid-day..."
    And it goes on. Make of it what you will.
    Reads like a hifi company has been taken over by Scientologists.
    I must say I have very little patience with kit that needs capacators hand-rolled in the Japanese forest on the thighs of virgins suitably earthed against static build-up .... I'd personally rather they spent the dosh on better transformers.
  7. #497
    I'd say it was more a task of balancing all the compromises that inevitably occur.
    Certainly for commercial operations cost is a major compromise, 'how much is that output transformer?!'
  8. #498
    Yes, just like following a recipe and balancing all the ingredients, so that the final 'dish' is tasty!
  9. #499
    I'm Gary.
    Which Manufacturer said this bollocks?
    AC POWER
    AMPS
    SPEAKERS
    Wharfedale Evo 4.4
    DAC
    TURNTABLE
    PHONOSTAGE
    DIGITAL
    MUSIC PLAYBACK
    Ipad Roon Remote.
    SPEAKER CABLES
    INTERCONNECTS
  10. #500
    I'm Gary.
    Graphene fuse element, is it fuckers like.
    Maybe wire coated in Graphene powder...
    I literally have no idea how graphene in used in this fuse.
    Website certainly gives no indication.
    AC POWER
    AMPS
    SPEAKERS
    Wharfedale Evo 4.4
    DAC
    TURNTABLE
    PHONOSTAGE
    DIGITAL
    MUSIC PLAYBACK
    Ipad Roon Remote.
    SPEAKER CABLES
    INTERCONNECTS
