Hunter S Thompson
Ha - best not go there!
The other thing that the man doesn't seem to get, indeed neither him nor his arse-licking illiterate solicitor, is that what's being objected to/disagreed with is NOT the subject of the 'Gaz fuse fiasco', or the points put forward within that, such as anything about him not believing a fuse can sound better than other fuses, but rather the aggressive tone, complete lack of civility and patronising way in which Gaz was being treated by both of them during the whole episode!!
Why on earth neither of them seem capable of discussing the subject of hi-fi, calmly and civilly, without getting personal with people, is something you'd have to assess with how (seemingly) ignorantly these folk were brought up by their parents! Both badly need taught some manners, and I feel certain that day will come.
The deep-rooted hostility in evidence is certainly the reason why the forum in question is (and always will be) of the 'no-mark' variety, populated in the main by small-minded trolls and keyboard warriors, all too keen to insult and vilify others, from the safety of their keyboards, but who aren't quite so keen to reveal their real names and/or locations... HFS: a 'no-mark' forum for life's angry inadequates and cowardly trolls...
Anyway, enough has been said on this now, so let's move on and return to the thread topic.
I'm Bob.
Get some fine emery paper and clean your existing fuse and fuse holder, replace the original fuse back in. Hey presto, an improvement if there is one and it cost £1. So that is £89 less than the foo fuse.
I own a lot of foo stuff, but not foo fuses. As usual, just regularily clean the contacts and that is the same as an "upgrade". Far to sensible, but LPs are quite expensive now and £89 buy's about 4 - 5.
A little story for you.
A few years back, I was reviewing a turntable – I set it running in my upstairs listening room to warm up and went downstairs to write the review introduction. About 20 minutes later, the power went off and I found that the RCD for the house sockets that included my listening room had tripped.
I reset it and went upstairs, assuming the review turntable had failed but it was fine and running happily still. However, through the thick fog of smoke in the room I noticed that the power LED on the phono stage I was using at the time was out. I went to remove it from the rack, burning my hand on the lid in the process, which was red hot, and took it downstairs to cool off!
To cut a long story short, one of the rectifier diodes had gone short circuit, overloading the transformer. There was no fusing on the transformer’s outputs so it just sat there cooking itself until its moulded enclosure melted and the windings made contact with the earthed case, tripping the breaker. Had a fuse been fitted on the output side, however, it would have blown.
Even ignoring the potential fire hazard due to the lack of fusing, instead of a repair bill of about £4 for 4 diodes and one fuse, it actually cost me around £50 to fix - 4 diodes, two nearby melted capacitors and one transformer, plus two fuses and fuseholders that I added to the transformer outputs to prevent such future events. Funnily enough, this left the sound completely unaffected!
Worst of all, my flippin’ listening room stank for weeks as well...
Pal of mine had an Audiolab 8000a which he left on all the time despite me saying this was a bad idea. Eventually it did fail while he was out of work. No fire but it did melt all over his tuner, ruining that as well. I leant him a tidy little Marantz amp (with VU meters) as a stop gap.
Clearly that was at least as good as the Audiolab as he still has it more than 20 years later.
The French distributor of these fuses actually recommends fitting the next size up as far as ratings go. This seems a bit daft to me.
Kevin
AC POWER
AMPS
SPEAKERS
Wharfedale Evo 4.4
DAC
TURNTABLE
PHONOSTAGE
DIGITAL
MUSIC PLAYBACK
Ipad Roon Remote.
SPEAKER CABLES
INTERCONNECTS
I'm joe.
I'm joe.
I've never had an amp blow up or catch fire (though an old Nytech I'd given away to a friend did go up in smoke when being used at 'party' volumes for several hours) but a laptop did emit foul-smelling smoke when its power supply developed a fault. Fortunately I was in the room when it happened, and chucked it into the garden before it did any real damage.
