I'm mike.
I think it is going to be system/gear dependent on whether a difference is heard.
I can appreciate Jez's stance on this but I must add a disclaimer to it. It will be down to how well the power supply/rectifiers/regulators are doing their job of removing mains related perturbations from the equation.
I think Jez is looking/assuming at a perfect power supply section, but not all are perfect.
Fair do's, Mike, and I would add a '+1' to that.
Essentially, Jez just needs to brush up on his people skills a bit, and most importantly understand and accept that not everyone thinks the same as he does, and to make allowances for that in future. We've had a chat about that, and he understands.
I like Jez (he knows that), and consider him an asset to the forum, simply because of his technical knowledge and straight talking. I also know he's happy to be here. He just needs to rein-in his 'excesses' a little, that's all
I haven't got an 'audiophile' fuse Marco ..
..so it would be a bit difficult to test.
Not that bit... I was referring to the testing of an old, well-used standard fuse, versus a brand new standard one (or a group of both, especially including ones with visible 'sagging filaments'), to see if there's any evidence that fuses 'deteriorate' over time, by measuring a higher resistance than they would've done when new....
Go on, give it a go and report back
P.S Try and do 'like for like' comparisons, by ensuring that the fuse value and manufacturer, as well as type (clear glass or ceramic-bodied, etc), are the same, in order to keep variables to a minimum.
And then a bit of copper wire in place of
How can you see if a ceramic fuse has a sagging filament?
Kevin
