Hi all,
New to the forum and vintage hi-fi too. Bear with me as i don't really know what i'm talking about.
I recently purchased a Heybrook TT2 and the platter is catching on the plinth. The problem seems to be caused by the central bearing being off center but if you try and center it with the three adjusting bolts they seem to have little effect. If any one that has experience of this type of deck, what is the likely cause of the issue, could it be the spring is out of alignment or something as simple as the M6 nut that holds the spring bushes in place needs tightening so as to lift the platter away from the plinth as at the moment there is also not the required 5mm gap between the platter and the plinth,.....
Is is this something an amateur can sort or does it need an expert and if it can be sorted by an amateur any suggestions/ hints on how to tackle this as i do not want to damage anything by just blundering in.
Thanks,
Bob
