Page 2 of 6 FirstFirst 1234 ... LastLast
Results 11 to 20 of 59
Thread: Celestion Ditton 66 recap
    I'm Rod.
    Hi Jamie
    Perhaps using a 'musical instrument' as an example is a bit misleading, as you say, the instrument is designed to work with more limited frequencies to produce those sounds. I've always found on modest sized cabinets, your latter example, using a more rigid cabinet using steel with carbon fibre where possible to keep the enclosure light but very stiff works well - it's surprising how little damping is required if the cabinet is tuned and braced correctly. My point was really to say that mass damping can lead to lifeless, dull sound.
    I think I'll be ordering some of the Alcaps from Falcon, I can't see the originals fairing too well - the 72uf measure well out of spec.
    Still haven't heard anything from Wilmslow about the 22uf Mundorf E-caps supplied as RAW not PLAIN.... not good customer service.
    I'm jamie.
    A small update,
    im still waiting for the Ansar super sound 1uf caps.
    I did however do as much as i can until they arrive on 1 board.
    In the meantime the Monitor Audio R852's are doing sterling service
    My System
    John Wood KT88 Amp.
    Paradise Phono Stage
    Sony TTS-8000 Turntable.
    PMAT-1010 MK6 Tonearm.
    Ortofon Cadenza Bronze
    Sony X555ES Cd Player
    Yamaha NS1000m Speakers
    I'm jamie.
    who's been a busy boy today then??
    the 1uf caps arrived today,this was no 5 minute job and my backs killing me!
    im aiming to have them up and running tomorrow
    My System
    John Wood KT88 Amp.
    I'm Rod.
    Looking good Jamie, my boards should look the same once I get the replacement Mundorf 22uf e-caps in the PLAIN type.
    Wilmslow Audio finally got back in touch, they seem to be quite slow in replying to emails, but they did state that they sent the Mundorf 22uf e-cap RAW types in error and are sending replacements which was encouraging. (The RAW types are a fraction of the physical size of the PLAIN type as you have so are easy to spot) I also mentioned the 'out of tolerance' Mundorf e-caps which they said they would try to rectify.
    What type of connecting cable did you go for, it looks similar gauge to the original cable used, and what is the foam packing material?
    Looking forward to hearing about the results when you get them together
    I'm jamie.
    hi rod,
    its 7.25am here in the uk and im just about to start putting them back together
    for the internal wire i used Van Damme Blue Series 0.75mm Studio Grade i just cut the sleeving off,as for the foam its for welding helmets,its stuck to the band that goes around you forehead to stop it rubbing your skin.we have loads a work.
    My System
    John Wood KT88 Amp.
    I'm Rod.
    That's good to know about the cabling - I think I'll just use some thin white polyethylene dense packing foam for my pads, or as you did whatever I have at hand - I would twist the cables where you can as this simple technique helps with screening the signal through the wires.
    Should have then up and running before lunch?
    Oooh... I can *feel* your excitement!
    Look forward to reading about your impressions
    I'm jamie.
    all finished a sounding much better,not night and day as the old cliche goes but definitely better.
    the balance between drivers has improved,the sound is more integrated if you know what i mean.the mid range has also benefited from the mundorf electrolytic and 1% poly mix as detailed in kens restoration thread.
    1st pic is the new binding posts fitted.
    i took the trouble to swap out the HF2000 tweeters for some red label HF2000's i bought from ken,these are supposedly earlier and better made.
    crossover fitted,
    its been a long slog doing these,id like to give the baffle board a freshen up with stain and also the grill cloths need some attention but for now im going to enjoy them.
    happy days
    My System
    John Wood KT88 Amp.
    Nice one, Jamie. Glad it seems to have worked out well! Looking forward to seeing the finished articles (in terms of your tarting up of the speakers physically), and some more thoughts on how they sound, once your ears fully adjust to all the changes
    Hi Jamie. Have you considered experimenting with the crossover location? Maybe situating it on the floor of the cabinets, away from any driver magnets, which could possibly have influence over the inductors.
